C4506 supervisor module temperature issue
nzell005
Frequent Visitor
Frequent Visitor
Hi I got an alarm from C4506R-E switch with temperature issue
It is how looks like
B_C4506_B2#show environment
warning alarm: slot 1 has exceeded the warning temperature for 1470h 42m 10s
Module Sensor Temperature Status
1 air inlet 49C (51C,65C,68C) warning
1 air outlet 61C (69C,83C,86C) ok
2 air inlet 31C (43C,58C,61C) ok
2 air outlet (front) 42C (51C,66C,69C) ok
2 air outlet (back) 32C (43C,58C,61C) ok
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-2800AC AC 2800W good good good
PS2 PWR-C45-2800AC AC 2800W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Orange
Module 1 Status Led Color : Orange
Module 2 Status Led Color : Green
Fantray : Good
Fantray removal timeout : 50
Power consumed by Fantray : 120 Watts
Module 1 is Active supervisor module and there is no standby sup module.
And Module 2 is interface module.
TPS room's temp is 28 degrees celcious
Should I replace the sup module? or what should I do in this case?
balaji.bandi
what is the version of Code running (this may be bug also)
if you get maintenance window, i would turn off the switch and bring back (if you have contract worth opening TAC case for RMA in case faulty).
BB
