Vss failover takes 10 minutes
ikoritana_sbet
We have a two 6509 chassis in vss mode (122-33.SXI6).
Currently a 'redundancy force-switchover' takes 10 minutes to complete (before we can access switch on management IP).  We are running sso with nsf.  Is this expected given standad HSA and we arent/cant run  RPR/+.
10 Replies 10
Reza Sharifi
That is not the correct behavior.  When you issue "'redundancy force-switchover" it usually takes less than a second for the other switch to take over and become the primary switch.  Can you post your config?
Also, can you post the output of " show switch virt detail"?
Is this what you need ?
MAL2-PR-SW01-1#sh swi virtual role detail ?
  |  Output modifiers
Switch  Switch Status  Preempt    Priority  Role     Session ID
        Number         Oper(Conf) Oper(Conf)         Local  Remote
LOCAL    1     UP      FALSE(N )   110(110)  ACTIVE   0      0
REMOTE   2     UP      FALSE(N )   100(100)  STANDBY  8548   2400
RRP Counters:
Inst. Peer Direction Req       Acc        Est        Rsugg       Racc
1     1      Tx      0          1          0          1          3
1     1      Rx      2          0          1          0          3
RRP FSM info:
sm(vslp_rrp RRP SM information for Instance 1, Peer 1), running yes, state role_res
Last transition recorded: (lmac)-> lstart (req)-> hold (srt_exp)-> hold (req)-> hold (est)-> role_neg (srt_exp)-> role_neg (racc)-> role_res (srt_exp)-> role_res (racc)-> role_res (racc)-> role_res (srt_exp)-> role_res (srt_exp)-> role_res
In dual-active recovery mode: No
just
show switch virtual
or
show switch virtual detail
MAL2-PR-SW01-1#               sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
MAL2-PR-SW01-1#
Can you delete this command, save the config and test the fail over again?
switch 1 priority 110
It now takes 30 seconds
I'm experiencing same issues on our cisco 9500-40x. Any suggestions? to fix
Attached config
Weezy-F
