Showing results forĀ
Search instead forĀ
Did you mean:Ā
%C4K_RKNOVA-4-INVALIDTOKENEXPIRED
Muhammed AKYUZ
hi,
we are getting this log from Catalyst 4500. What kind of problem should it be?
Dec  6 11:18:57.800: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 28389 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967288
9 Replies 9
Somasundaram Jayaraman
Hi Muhammed,
In most cases this error messages will appear if wccp is configured and it is not supported by the supervisor engine installed.
There are some cosmetic bugs related to this as well.
Could you please post the show version & show module output?
Cheers
Somu
sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.01.01.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 14-Dec-10 21:30 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x1009E914, data-base: 0x13B71550
ROM: 15.0(1r)SG1
Jawa Revision 7, Snowtrooper Revision 0x0.0x15
4500-NEW uptime is 24 weeks, 19 hours, 21 minutes
Uptime for this control processor is 24 weeks, 16 hours, 4 minutes
System returned to ROM by reload
System restarted at 18:19:42 EEST Tue Jun 21 2011
Running default software
Last reload reason: Reload command
License Information for 'WS-X45-SUP7-E'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
cisco WS-C4510R+E (MPC8572) processor (revision 8) with 786516K/16384K bytes of memory.
Processor board ID FOX1513H1HM
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from Reload
43 Virtual Ethernet interfaces
102 Gigabit Ethernet interfaces
20 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    12  10GE SFP+                              WS-X4712-SFP+E     CAT1511L0DT
2     6  1000BaseX (GBIC)                       WS-X4306-GB        JAE1048G5YV
5     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1515L03L
6     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1515L00L
9    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1049GJNX
10    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1049GL3W
M MAC addresses                    Hw  Fw           Sw               Status
1 0026.0b79.f246 to 0026.0b79.f251 1.1                               Ok
2 0016.c75e.ff20 to 0016.c75e.ff25 4.2                               Ok
5 6400.f1e6.ea00 to 6400.f1e6.ea03 1.0 15.0(1r)SG1  03.01.01.SG      Ok
6 6400.f1e6.ea04 to 6400.f1e6.ea07 1.0 15.0(1r)SG1  03.01.01.SG      Ok
9 0012.d972.a5c0 to 0012.d972.a5ef 2.3                               Ok
10 0012.d972.a410 to 0012.d972.a43f 2.3                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
5   Standby Supervisor  SSO                 Standby hot
6   Active Supervisor   SSO                 Active
System Failures:
Power Supply:   bad/off (see 'show power')
sh ip wccp
Global WCCP information:
    Router information:
        Router Identifier:                   1.1.1.199
        Protocol Version:                    2.0
    Service Identifier: 61
        Number of Service Group Clients:     1
        Number of Service Group Routers:     2
        Total Packets s/w Redirected:        0
          Process:                           0
          CEF:                               0
        Redirect access-list:                WCCP_LAN_TO_WAN_61
        Total Packets Denied Redirect:       8594844
        Total Packets Unassigned:            0
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total Bypassed Packets Received:     0
    Service Identifier: 62
          Process:                           0
          CEF:                               0
        Redirect access-list:                WCCP_WAN_TO_LAN_62
        Total Packets Denied Redirect:       0
I am seeing the same error in the logs of a box I deployed last night.  There is no WCCP configured on this device.  I am running cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin code with redundent Sup 7L-E 10GE (SFP+).
Anyone have another thought on what this could be from.  My install is a very simple L2 access switch.
Pat
Brendan Marmont
Hi, I have the same entry appearing in my logs, did you find a resolution for this topic?
Cheers,
Brendan
Upgrade to cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin has resolved the issue. Indeed i believe it was due to wccp.
I'm running cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin with no WCCP.
The release notes indicate this is a cosmetic issue related to OIR of linecards.
Reboot and it will most likely clear.   I haven't had a chance to reboot and verify yet.
patrickh99,
Did you ever reboot your switch?  Did it clear up the error message?  The reason I ask is this recently appeared on one of my 4507's.  I'm running 03.03.02.SG.151-1.SG2.
Thx,
Tone
I don't have wccp enabled, but still encountering this issue.
Kias
Fonicom Limited
raiseaticket Malta
jacobbriggs
Same issue here, logs are full of error.
063435: 004230: Oct 27 15:07:51.431 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063436: 004231: Oct 27 15:12:54.433 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063437: 004232: Oct 27 15:17:57.435 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063438: 004233: Oct 27 15:23:00.437 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
Any definitive root cause discovered here? cat4500e-universalk9.SPA.03.03.02.SG.151-1.SG2.bin
