%C4K_SWITCHMANAGER-4-S2WERRORREPORT
ney25
Level 7
Level 7
Hi netpro,
anyone knows about this ?
Log Buffer (4096 bytes):
2w Read/Write Error for port Fa3/10.
Oct 2 06:04:10.503: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/10.
Oct 2 06:09:10.557: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/1.
Oct 2 06:14:10.560: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/1.
Oct 2 06:19:10.591: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 06:24:10.623: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 06:29:10.665: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 10 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/17.
Oct 2 06:34:10.728: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 9 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/37.
Oct 2 06:39:10.855: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 5 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/42.
Oct 2 06:44:10.924: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 06:49:10.929: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/42.
Oct 2 06:54:11.032: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/10.
Oct 2 06:59:11.042: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/17.
Oct 2 07:04:11.063: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 07:09:11.144: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/1.
Oct 2 07:14:11.195: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/37.
Oct 2 07:19:11.262: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 5 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/42.
Oct 2 07:24:11.304: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/10.
Oct 2 07:29:11.356: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 11 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/1.
Oct 2 07:34:11.398: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/1.
Oct 2 07:39:11.534: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/17.
Oct 2 07:44:11.643: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/17.
Oct 2 07:49:11.717: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 3 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 07:54:11.793: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 7 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/17.
Oct 2 07:59:11.814: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/10.
Oct 2 08:04:11.860: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 11 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/25.
Oct 2 08:09:12.005: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 10 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/37.
Oct 2 08:14:12.002: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa3/37.
your reply will be highly appreciated.
thanks.
regards,
Jackal
ajagadee
Checkout Bug ID CSCef87815.
Error Message C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write
Error for port [char].
Explanation This message indicates that a read/write error has occurred on the specified port.
Recommended Action Verify whether you can see all the symptoms described in the release notes for CSCef87815. If not and you do not see any adverse effect on the functionality of the PoE linecards (WS-X4248-RJ45V, WS-X4248-RJ21V, WS-X4548-RJ45V, WS-X4224-RJ45V or WS-X4524-RJ45V), treat this message an informational only. No action is required.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ew/system/message/emsg.html
I hope it helps.
Arul
** Please rate all helpful posts **
