C5548 and C5010
MarkLiman1783
Hello, can anyone answer my questions regarding these switches please.
1. What are the advantages of the newer 5500 models
2. Am I able to use these as normal 10gbe switches without Fibre Channel
Reza Sharifi
The Nexus series switches are designed for data center use. If you don't need fiber channel support, you can get the non-UP version of these switches. How many 10Gig ports do you need? Do they need to be copper or fiber?
7 Replies 7
Reza Sharifi
Ok perfect so I can get a c5010 or a c5548p and that will work fine with Cisco DAC sfp cables I am planning to use 16 or so fibre ports some of those going to a Gigabit FEX, also what is the diffirence between those two ? Just better hardware ?
As per i know both models are EoS, suggest to go with nexus 5572UP
BB
I can't find the 5572UP so what would you suggest me to go with a c5010p , c5548p or c5548up
Sorry its typo 5672UP, i prefer to buy c5548up
BB
Ok However you said I don't need the up version in my scenario as Fc is useless to me
Correct. You don't need UP (Universal Ports) version if you are not using it for FCOE.
