C6500 Storm control - Different level for Broadcast & Multicast
parisdooz12
we configured broadcast storm control on our C6500. We would like now to add multicast storm control, but with another value (bigger) than for broadcast.
The problem is when I configure multicast level, it changes automatically the value for broadcast.
Is it a way to avoid that?
Regards.
D.
Reza Sharifi
That is a normal behavior.  If you configure broadcast at 5% and than later configure multicast at 7%, the router will change the broadcast to 7%.
have a look at this example:
This example shows how the traffic storm control level configured for one mode affects all other modes that are already configured on the Gigabit Ethernet interface 4/10:
Router# show run inter gig4/10
Building configuration...
Current configuration : 176 bytes
Router# interface GigabitEthernet4/10
Router# switchport
Router# switchport mode access
Router# storm-control broadcast level 0.5
Router# storm-control multicast level 0.5
Router# spanning-tree portfast edge
Router# end
Router# configure terminal
Router(config)# interface gigabitethernet 4/10
Router(config-if)# storm-control unicast level 0.7
Router(config-if)# end
Router# show interfaces gig4/10 counters storm-control
Port UcastSupp % McastSupp % BcastSupp % TotalSuppDiscards
Gi4/10 00.70 00.70 00.70 0
Router#
config guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/storm.html
This behavior is not really nice as broadcast traffic is normally less important that multicast.
If I have, let's say, video on my network, I would like to have a limit of 50 Mbps for multicast.
Beside that, I want my have a broadcast limit of  5Mbps, to protect my CPU.
Is there a solution?
Hi! This thread is quite old, but maybe somebody will still read it. As you can see from the output, the same value applies to UNICAST traffic also, and that's a problem! This is an obvious bug. Is there any solution to it? Best regards.
