C6509-E + SUP2T + 15.1 + Flexible Netflow Error: could not get flow def
Hilario Martin
Level 4
Level 4
I am trying to configure Flexible Netflow on a C6509-E with SUP2T but I get this error from IOS:
Aug 24 16:36:40 GMT: FLOW MON: Created Monitor: -888760999
Aug 24 16:36:40 GMT: FLOW MON:  'test' could not get flow def
 flow monitor test
 description "test"
 exporter test-FNF-EXPORT
 record test-FNF-RECORD
I do not consider necessary to include configuration of  Record/Export (cache statistics and export NetFlow collector are zero)
The problem is caused when the flow monitor command is entered and logging immidiately returns:
I have followed this doc http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11-652021.html (Cisco Catalyst 6500 Supervisor Engine 2T - NetFlow Enhancements White Paper) configuring another C6506 successfully.
Do I need to activate any other command/funtionality?
I am working with: (s2t54-IPSERVICESK9-M), Version 15.1(2)SY4a
I appreciate any comments
Thanks in advance!
Don Jacob
I havent seen that error message ever nor could I find it. Can you try contacting
https://www.cisco.com/pcgi-bin/Support/Errordecoder/index.cgi
R,
Don Jacob
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
Hi Jacob,
I checked error message in the tool "Error Message Decoder" but there is no reference related to my issue.
Thanks for your recomendation!
I am quite intrigued. Even Cisco 6500 series error codes dont list it. Let me sound stupid - but have you tried changing the name from test?
Indeed, I have tried several names with the same result.
One thing to consider is that after enabling hardware flow (the default configuration comes with no hardware flow) asked for a system reboot.
I searched in the document cited above (and others) if it is really necessary to reboot the switch after enabling NetFlow but have found no reference.
Thanks!
