C6840-X VSS
camo
We have two C6840-X-LE-40G, with 40x10G SPF+  and 2x40G QSFP ports.
1. Can we make a VSL using only 2x10G from each of these two switch (without using the 40G SUP card)?
2. Can a VSL be make using only one link in the port-channel?
7 Replies 7
balaji.bandi
If I understand corectly you like to use Link card port for VSL- if this is correct Answer is NO.
Since your supervisor boot first and later Line card will be coming online, Supervisor required to check VSS peer device
BB
Thanks sir.
The switch has a SUP with 2x40G ports. can we use only one of them.
Suggest VSS design always 2 Links(so you will not have split-brain due to link loss in a production environment), instead of using 40GB links, you can use 2 X 10GB links
BB
I thought from your first answer that I can not use the 10GB links.
can I use them for the VSS (VSL)?
You can use 10GB - onboard supervisor ports - not the Line card for VSL.
BB
Ports on linecard also can be used for VSL, without using ports on supervisor.
As I mentioned:
1. Yes, you can use 10G and 40G ports on particular linecards for VSL, without using ports on supervisor, though it's not recommended due to possible split-brain scenario. VSL ports are special type ports and they are initialized before even full bootup.
2. Yes, you can use single link within Port-channel for VSL, though again, it's not recommended due to redundancy issues.
You can check VSL hardware requirements here:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-5SY/config_guide/sup6T/15_5_sy_swcg_6T/virtual_switching_systems.html#pgfId-1053927
vb10
Please, find my comments below:
