C6880-X VSS with FEX Upgrade
Maxee
I recently inherited a C6880-X VSS Cluster in one of our buildings for doing maintenance and software upgrade. Nobody really wanted to do it because there are over 400 access ports attached ... But I think it is necessary for security reasons.
Now I don't know how to do it with minimal downtime. Normally I would go the ISSU route but the version difference is too big.
Current version: 15.2.1-SY1a (NPE)
Goal: 15.5.1-SY4 (non-NPE)
Can I go directly from 15.2.1 to 15.5.1 without ISSU or eFSU or do I have to take some steps between? Even with ISSU I have to reload the FEX-Switches... and with ISSU I have to do a lot of steps.
Do you have recommendations?
Any help is appreciated
Thanks!
balaji.bandi
Read the relase noted carefully ( check ROMMON Verson, what you have it may required to upgrade depens on exiting one installed)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-5SY/release_notes/release_notes_15_5_SY.html#pgfId-5359511
The upgrade can be done 2 ways, traditional way :( depends how your FEX connected ? is this dual home or single Homed ?)
Tradional  way :
- Copy the IOS to the primary bootflash:
- Copy the IOS to the secondary bootflash:
- Remove the boot variable string pointing to the old IOS
- Add the new boot variable string pointing to the new IOS
- Insert the boot variable string pointing to the old IOS
- Make sure the config-registry is 0x2102
- Save the config
- Reboot ( this means downtime required)
If you go ISSU Route : below guide help you.
https://howdoesinternetwork.com/2016/6880-issu
BB
Thanks for the answer.
My FEX are all dual homed. I read that ISSU article but it only describes the minor upgrade path.
The ROMMON currently is 15.1(02)SY01. If I go the traditional way can I take the big step? I didn't find anything related to ROMMON or required versions in the release notes for the newest version
I have verified and it seems to me that in the compatibility matrix of the ISSU way there is no upgrade directly from 15.2 to 15.5 so you have to proceed with the traditional way.
Best Regards
