C9200-24P cleaning flash
SergeyKunitsa1
We have stack with two C9200-24P switches.
Flash of first switch displays
1956839424 bytes total (845697024 bytes free)
Flash of second switch:
1957167104 bytes total (1358430208 bytes free)
I compare content of two flashes - it`s identical (+/- several Mb).
We try to clean this flash, but "squeeze flash" command is unreachable, "install remove inactive" does not give any result/
So, can anybody help us to understand - why we have so few free space on first flash, and how we can clean this flash?
oelghann
Hello Sergey,
You're hitting CSCwa71156.
1. Reload the active member switch, so that Standby takes the active role.
2. Perform the following Commands, when Switch 2 is now the active member.
#conf t
#iox
#end
#guestshell enable
#guestshell destroy
#conf t
#no iox
#end
- Now try the upgrade again, it should work. If the reload isn’t possible, then please raise case with Cisco TAC, to access the Shell, and remove the iox files.
16 Replies 16
balaji.bandi
what is the version of IOS XE running
post dir output here.
BB
Version 17.3.5
Directory of flash:/
64813 -rw- 656 Feb 14 2023 18:07:53 +01:00 DHCP_SNOOP_DATA.txt
64771 drwx 4096 Feb 13 2023 13:17:26 +01:00 .installer
24291 drwx 4096 Feb 13 2023 13:04:24 +01:00 license_evlog
64799 -rw- 2097152 Feb 6 2023 23:15:11 +01:00 nvram_config_bkup
64798 -rw- 2097152 Feb 6 2023 23:15:11 +01:00 nvram_config
64802 -rw- 1036 Feb 6 2023 22:59:45 +01:00 stby-vlan.dat
64815 -rw- 0 Feb 6 2023 22:57:37 +01:00 dope_hist
64792 -rw- 15500 Feb 6 2023 22:57:37 +01:00 rdope_out.txt
64793 -rw- 89 Feb 6 2023 22:57:33 +01:00 rdope.log
64801 -rw- 1036 Feb 6 2023 22:57:28 +01:00 vlan.dat
105249 drwx 4096 Feb 6 2023 22:57:19 +01:00 .prst_sync
64780 -rw- 134458 Feb 6 2023 22:56:09 +01:00 memleak.tcl
64770 -rw- 2148 Feb 6 2023 22:55:54 +01:00 boothelper.log
8120 drwx 4096 Feb 6 2023 22:55:52 +01:00 dc_profile_dir
64774 -rw- 370 Feb 6 2023 22:55:33 +01:00 bootloader_evt_handle.log
64812 -rw- 427349016 Feb 6 2023 22:29:37 +01:00 cat9k_lite-rpbase.17.03.05.SPA.pkg
64778 -rw- 2149 Aug 26 2022 11:23:12 +02:00 boothelper.log.old
64808 drwx 4096 Aug 1 2022 15:23:29 +02:00 .rommon_sync
64791 drwx 4096 Jul 8 2022 03:21:48 +02:00 .dbpersist
97153 drwx 4096 Jul 8 2022 03:09:36 +02:00 .rollback_timer
24309 -rw- 40713581 Jul 8 2022 03:04:17 +02:00 cat9k_lite-rpboot.17.03.05.SPA.pkg
24305 -rw- 4920 Jul 8 2022 03:04:17 +02:00 packages.conf
24308 -rw- 11043860 Jul 8 2022 03:02:56 +02:00 cat9k_lite-webui.17.03.05.SPA.pkg
24307 -rw- 4367384 Jul 8 2022 03:02:56 +02:00 cat9k_lite-srdriver.17.03.05.SPA.pkg
64803 drwx 4096 Jul 8 2022 02:57:00 +02:00 pnp-tech
64775 drwx 4096 Jul 8 2022 02:56:39 +02:00 core
64796 drwx 4096 Jul 8 2022 02:56:35 +02:00 guest-share
72865 drwx 4096 Jul 8 2022 02:56:17 +02:00 pnp-info
64794 drwx 4096 Jul 8 2022 02:56:17 +02:00 onep
64781 drwx 4096 Jul 8 2022 02:55:10 +02:00 Tbot
8122 drwx 4096 Jul 8 2022 02:55:04 +02:00 sys_report
8097 drwx 4096 Jul 8 2022 02:55:02 +02:00 tech_support
64777 drwx 4096 Jul 8 2022 02:55:02 +02:00 ss_disc
64776 -rw- 5242880 Jul 8 2022 02:55:02 +02:00 ssd
105252 drwx 4096 Jul 8 2022 02:55:02 +02:00 gs_script
Directory of flash-2:/
32386 drwx 4096 Feb 13 2023 13:18:11 +01:00 license_evlog
24291 drwx 4096 Feb 13 2023 13:17:24 +01:00 .installer
24318 -rw- 2097152 Feb 6 2023 23:15:13 +01:00 nvram_config_bkup
24317 -rw- 2097152 Feb 6 2023 23:15:13 +01:00 nvram_config
24298 -rw- 1036 Feb 6 2023 23:00:11 +01:00 vlan.dat
64769 drwx 4096 Feb 6 2023 22:59:48 +01:00 .prst_sync
24311 -rw- 15500 Feb 6 2023 22:57:38 +01:00 rdope_out.txt
24331 -rw- 0 Feb 6 2023 22:57:38 +01:00 dope_hist
24312 -rw- 89 Feb 6 2023 22:57:35 +01:00 rdope.log
24300 -rw- 134458 Feb 6 2023 22:56:09 +01:00 memleak.tcl
24293 -rw- 2148 Feb 6 2023 22:55:54 +01:00 boothelper.log
89080 drwx 4096 Feb 6 2023 22:55:51 +01:00 dc_profile_dir
24294 -rw- 481 Feb 6 2023 22:55:33 +01:00 bootloader_evt_handle.log
24290 -rw- 2149 Aug 26 2022 11:23:13 +02:00 boothelper.log.old
24329 drwx 4096 Aug 26 2022 11:21:25 +02:00 .rommon_sync
24321 -rw- 856 Aug 1 2022 15:21:55 +02:00 stby-vlan.dat
24323 -rw- 47 Jul 21 2022 12:45:19 +02:00 DHCP_SNOOP_DATA.txt
24322 drwx 4096 Jul 4 2022 16:00:10 +02:00 pnp-tech
56673 drwx 4096 May 23 2022 12:48:27 +02:00 .rollback_timer
97175 -rw- 40713581 May 23 2022 12:43:09 +02:00 cat9k_lite-rpboot.17.03.05.SPA.pkg
97171 -rw- 4920 May 23 2022 12:43:09 +02:00 packages.conf
97174 -rw- 11043860 May 23 2022 12:41:31 +02:00 cat9k_lite-webui.17.03.05.SPA.pkg
97173 -rw- 4367384 May 23 2022 12:41:31 +02:00 cat9k_lite-srdriver.17.03.05.SPA.pkg
97172 -rw- 427349016 May 23 2022 12:41:31 +02:00 cat9k_lite-rpbase.17.03.05.SPA.pkg
24310 drwx 4096 May 23 2022 12:38:01 +02:00 .dbpersist
24295 drwx 4096 May 23 2022 12:35:19 +02:00 core
24315 drwx 4096 May 23 2022 12:35:18 +02:00 guest-share
105251 drwx 4096 May 23 2022 12:34:58 +02:00 pnp-info
24313 drwx 4096 May 23 2022 12:34:57 +02:00 onep
89082 drwx 4096 May 23 2022 12:34:00 +02:00 .USWAP
24301 drwx 4096 May 23 2022 12:33:51 +02:00 Tbot
113345 drwx 4096 May 23 2022 12:33:50 +02:00 .CRFT
24299 drwx 4096 May 23 2022 12:33:45 +02:00 sys_report
89057 drwx 4096 May 23 2022 12:33:43 +02:00 tech_support
24297 drwx 4096 May 23 2022 12:33:43 +02:00 ss_disc
24296 -rw- 5242880 May 23 2022 12:33:43 +02:00 ssd
64772 drwx 4096 May 23 2022 12:33:43 +02:00 gs_script
So the query here flash one consumed more compare to flash two right ?
you need to check manually any folder has more content ?
folder you can identify - drwx
BB
I already did this - the content of both flashes is identical.
To check the folder`s content I used dir /recursive flash:
Not sure never seen this before...next, i am guessing is to reboot the stack if the device has long uptime. (not sure if this fix the issue)
I am sure some files are hidden somewhere.,...
BB
and already rebooted without any results
uptime is 1 week, 2 days, 11 hours, 19 minutes
maybe I have on flash big file(s) (such as IOS image) which marked as deleted, but not deleted physically?
How I can clear this files?
In previous families was a command "squeeze flash" but in 9200 it unavailable
- we do not see like that as per your output , where did you see that ?
you already did /recursive to delete (command reference )
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-11/configuration_guide/sys_mgmt/b_1611_sys_mgmt_9200_cg/working_with_the_flash_file_system.html
BB
I don`t see that, this is my proposal, because I don`t know, where lost 500Mb
Leo Laohoo
delete /f /r flash:/tracelogs/*.gz
The folder flash:/tracelogs isn`t precent on flash
#delete /f /r flash:/tracelogs/*.gz
No such file
Post the complete output to the following commands:
  1. dir flash-1:core
  2. dir flash-2:core
Output below
Directory of flash:/core/
64797 -rw- 1 Feb 16 2023 08:13:11 +01:00 .callhome
113345 drwx 4096 Jul 8 2022 02:54:59 +02:00 modules
Directory of flash:core/modules/
No files in directory
Directory of flash-2:/core/
24316 -rw- 1 Feb 16 2023 08:18:31 +01:00 .callhome
72865 drwx 4096 May 23 2022 12:33:41 +02:00 modules
Directory of flash-2:core/modules/
Looks fine.
oelghann
Hello Sergey,
#conf t
#iox
#end
#guestshell enable
#guestshell destroy
#conf t
#no iox
#end
