C9200 Switch not able to authenticate with AD Server.
Tabish Hussain
Hi Team,
I am not able to authenticate one switch C9200 with AD server. All other switches are authenticated and working fine.
Below is my config. Please advise.
New SW Backup 10.9.22.15
__________________________________________
SERVERROOM#sh run
Building configuration...
Current configuration : 21225 bytes
! Last configuration change at 10:58:03 UTC Thu Jan 18 2024
version 17.9
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime
service timestamps log datetime localtime
service password-encryption
no service dhcp
! Call-home is enabled by Smart-Licensing.
service call-home
platform punt-keepalive disable-kernel-core
hostname SERVERROOM
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
aaa group server tacacs+ TACACS_ISE
 server name ITSS-ISE-KDC
 server name ITSS-ISE-SDC
aaa group server radius RADIUS-GROUP
 server name HOTDELDC001
server name ITCHTLWELAVPAT ! aaa authentication login default group TACACS_ISE local aaa authentication enable default enable aaa authentication dot1x default group RADIUS-GROUP aaa authorization exec default group TACACS_ISE if-authenticated aaa authorization commands 1 default group TACACS_ISE if-authenticated aaa authorization commands 7 default group TACACS_ISE if-authenticated aaa authorization commands 15 default group TACACS_ISE if-authenticated aaa authorization network default group RADIUS-GROUP aaa accounting dot1x default start-stop group RADIUS-GROUP aaa accounting exec default start-stop group TACACS_ISE aaa accounting commands 15 default start-stop group TACACS_ISE ! ! aaa session-id common ! ! ! boot system switch all flash:cat9k_lite_iosxe.17.06.05.SPA.bin switch 1 provision c9200l-48p-4x ! ! ! ! ! ip domain name itc.in ! ! ! login on-success log vtp version 1 ! ! ! ! ! ! flow record FNF-input description IPv4 NetFlow match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match ipv4 protocol match interface input match ipv4 tos match flow direction collect interface output collect counter bytes long collect counter packets long collect transport tcp flags collect timestamp absolute first collect timestamp absolute last ! ! flow record FNF-output description IPv4 NetFlow match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match ipv4 protocol match interface output match ipv4 tos match flow direction collect interface input collect counter bytes long collect counter packets long collect transport tcp flags collect timestamp absolute first collect timestamp absolute last ! ! flow exporter Scrutinizer description Export to Scrutinizer destination 10.9.22.63 source Vlan1 transport udp 2055 template data timeout 60 ! ! flow monitor Scrut_mon_input description IPv4 FNF ingress exports exporter Scrutinizer cache timeout active 60 record FNF-input ! ! flow monitor Scrut_mon_output description IPv4 FNF egress exports exporter Scrutinizer cache timeout active 60 record FNF-output ! ! crypto pki trustpoint SLA-TrustPoint enrollment pkcs12 revocation-check crl ! crypto pki trustpoint TP-self-signed-3386641013 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-3386641013 revocation-check none rsakeypair TP-self-signed-3386641013 ! crypto pki trustpoint TP-self-signed-2427689774 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2427689774 revocation-check none rsakeypair TP-self-signed-2427689774 ! ! crypto pki certificate chain SLA-TrustPoint certificate ca 01 30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030 32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934 3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720 526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030 82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520 1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE 4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC 7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188 68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7 C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191 C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44 DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201 06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85 4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500 03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905 604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8 467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C 7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B 5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678 80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB 418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0 D697DF7F 28 quit crypto pki certificate chain TP-self-signed-3386641013 certificate self-signed 01 30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 33333836 36343130 3133301E 170D3234 30313138 31303232 34385A17 0D333430 31313731 30323234 385A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33383636 34313031 33308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201 0A028201 0100A920 94DECCF0 6098AE11 9802F7F2 775F99A1 632ACD27 7617354B 8133E8F4 577EC553 1FD1B6F5 D729CA20 79601ABD FE96BE6D 94B0068A 1644405B 51883763 8BF2D29C A30EA5E3 A29DCB2A 63677166 F089C592 F4950BF1 E6413267 6BDC28F2 C80C28AF 45ADAB67 3BFCA4E5 6B886991 270D8CF2 42A3E9CB 3348C04E 4C2A77BD ACDBE557 C05DC1A2 9BC3C3A6 30C7C208 1BBFDD94 33364B12 7DF41F48 707B7AAE 03A38E8A D2799BFA 1FCDBBAB 7819BFE4 8972B6BA 4D88E078 3EBED29C F7D083EB 859165E4 AB2CD794 A9C873F2 427F1C80 4F65A717 9763D85C 3791A9D3 B2B8437E AD96790E 7A8AFDFC 68C9143C 2E3E12A8 F32B5B0D 9E706150 4E00BB85 2DA79FB9 EAD30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304 18301680 143189DB FDF1549A ADAE8712 33F8D553 57607E6E 33301D06 03551D0E 04160414 3189DBFD F1549AAD AE871233 F8D55357 607E6E33 300D0609 2A864886 F70D0101 05050003 82010100 8A914AFB 6BCF98B6 F138CE6C 05C68589 8AD00D06 020B259C F0E7B9A5 2FC873C5 832E5238 1BDB72DA 14E7F144 5FFE2CF4 1F8B9554 9DA9837A 2505CDC3 1E32C378 53AB2DE5 D4DE4878 46E70AD6 92AC6504 A0663AD8 2DB9815F 88C1CB05 E87D2010 281650B0 5BC281B0 7F6E34F1 876A6119 89DC1545 D5E1ACA6 923F7C9B E6763671 657E6649 061BF2A7 CD8735A3 9A4EEFA8 C392C373 92A7EF7F C89BDC47 EA3C0D20 5A904AC4 47BC976F 34111513 398A2A56 C615AC2B A8A695D8 91EEC604 5B2F717A F0AE270C 9FDC57A7 DCD5C2B2 47A6C7E0 03B9D395 81B72087 4BAB1261 BE737AA8 7A08A66F 2835D07B 7679B91C 4C4E2E92 1AFA2E64 41F40C6A EC4353E1 63B7C407 quit crypto pki certificate chain TP-self-signed-2427689774 ! license boot level network-essentials addon dna-essentials dot1x system-auth-control memory free low-watermark processor 10626 ! diagnostic bootup level minimal ! spanning-tree mode pvst spanning-tree extend system-id ! ! ! enable password 7 045A0F0B062F6C1F5B4A ! username admin password 7 0005170B0D552B575D72 ! redundancy mode sso crypto engine compliance shield disable ! ! ! ! ! transceiver type all monitoring ! lldp run ! class-map match-any system-cpp-police-ewlc-control description EWLC Control class-map match-any system-cpp-police-topology-control description Topology control class-map match-any system-cpp-police-sw-forward description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic class-map match-any system-cpp-default description EWLC data, Inter FED Traffic class-map match-any system-cpp-police-sys-data description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed class-map match-any system-cpp-police-punt-webauth description Punt Webauth class-map match-any system-cpp-police-l2lvx-control description L2 LVX control packets class-map match-any system-cpp-police-forus description Forus Address resolution and Forus traffic class-map match-any system-cpp-police-multicast-end-station description MCAST END STATION class-map match-any system-cpp-police-high-rate-app description High Rate Applications class-map match-any system-cpp-police-multicast description MCAST Data class-map match-any system-cpp-police-l2-control description L2 control class-map match-any system-cpp-police-dot1x-auth description DOT1X Auth class-map match-any system-cpp-police-data description ICMP redirect, ICMP_GEN and BROADCAST class-map match-any system-cpp-police-stackwise-virt-control description Stackwise Virtual OOB class-map match-any non-client-nrt-class class-map match-any system-cpp-police-routing-control description Routing control and Low Latency class-map match-any system-cpp-police-protocol-snooping description Protocol snooping class-map match-any system-cpp-police-dhcp-snooping description DHCP snooping class-map match-any system-cpp-police-ios-routing description L2 control, Topology control, Routing control, Low Latency class-map match-any system-cpp-police-system-critical description System Critical and Gold Pkt class-map match-any system-cpp-police-ios-feature description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed ! policy-map system-cpp-policy ! ! ! ! ! ! ! ! ! ! ! interface GigabitEthernet0/0 vrf forwarding Mgmt-vrf no ip address shutdown ! interface GigabitEthernet1/0/1 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/2 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 40b0.3425.1d5f switchport port-security ! interface GigabitEthernet1/0/3 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/4 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/5 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/6 switchport access vlan 17 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0892.04d5.bb13 switchport port-security ! interface GigabitEthernet1/0/7 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/8 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/9 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/10 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/11 ! interface GigabitEthernet1/0/12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/13 ! interface GigabitEthernet1/0/14 switchport mode access ! interface GigabitEthernet1/0/15 switchport access vlan 17 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/16 switchport access vlan 17 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky a41f.728f.c9d9 switchport port-security ! interface GigabitEthernet1/0/17 switchport access vlan 17 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky f48e.38af.c8fe switchport port-security ! interface GigabitEthernet1/0/18 shutdown ! interface GigabitEthernet1/0/19 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/20 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/21 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/22 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/23 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/24 switchport access vlan 11 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/25 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0019.17b1.16d8 switchport port-security ! interface GigabitEthernet1/0/26 switchport access vlan 16 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/27 switchport access vlan 16 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky e454.e8d7.fad0 switchport port-security ! interface GigabitEthernet1/0/28 switchport access vlan 16 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky f48e.38a8.30ff switchport port-security ! interface GigabitEthernet1/0/29 switchport access vlan 16 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky f8bc.1293.0824 switchport port-security ! interface GigabitEthernet1/0/30 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 40b0.3425.1d71 switchport port-security ! interface GigabitEthernet1/0/31 switchport access vlan 12 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky f48e.38bc.c1f5 switchport port-security ! interface GigabitEthernet1/0/32 switchport access vlan 12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/33 switchport access vlan 12 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky e454.e8d8.39d8 switchport port-security ! interface GigabitEthernet1/0/34 switchport access vlan 12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/35 switchport access vlan 12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/36 switchport access vlan 12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/37 switchport access vlan 12 switchport mode access switchport port-security authentication host-mode multi-host authentication port-control auto dot1x pae authenticator ! interface GigabitEthernet1/0/38 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0090.cc00.0699 switchport port-security ! interface GigabitEthernet1/0/39 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0090.cc00.0223 switchport port-security ! interface GigabitEthernet1/0/40 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0090.c500.0a7f switchport port-security ! interface GigabitEthernet1/0/41 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0090.c500.131d switchport port-security ! interface GigabitEthernet1/0/42 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0019.17b9.6341 switchport port-security ! interface GigabitEthernet1/0/43 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky 0019.17b1.170c switchport port-security ! interface GigabitEthernet1/0/44 switchport mode access switchport port-security violation restrict switchport port-security mac-address sticky switchport port-security mac-address sticky e8d8.d1b0.e85c switchport port-security ! interface GigabitEthernet1/0/45 switchport mode trunk ! interface GigabitEthernet1/0/46 switchport mode trunk ! interface GigabitEthernet1/0/47 switchport mode trunk ! interface GigabitEthernet1/0/48 switchport mode trunk ! interface TenGigabitEthernet1/1/1 ! interface TenGigabitEthernet1/1/2 ! interface TenGigabitEthernet1/1/3 ! interface TenGigabitEthernet1/1/4 ! interface Vlan1 ip flow monitor Scrut_mon_input input ip flow monitor Scrut_mon_output output ip dhcp client client-id ascii FOC27166Y2K ip address 10.9.22.15 255.255.255.0 ! ip default-gateway 10.9.22.10 ip http server ip http authentication local ip http secure-server ip http client source-interface Vlan1 ip forward-protocol nd ip tacacs source-interface Vlan1 ip ssh version 2 ! ! ip radius source-interface Vlan1 logging source-interface Vlan1 logging host 10.9.11.2 ! snmp-server community !+chotel@953 RO snmp-server community !+cblr@953 RO snmp-server host 10.9.22.63 version 2c !+cblr@953 snmp-server host 10.9.22.97 !+chotel@953 tacacs-server directed-request tacacs server ITSS-ISE-KDC address ipv4 10.10.200.111 key 7 07042E4045080D043743595F tacacs server ITSS-ISE-SDC address ipv4 10.10.100.111 key 7 0450040A0420584F29485744 radius-server dead-criteria time 60 radius-server deadtime 30 radius-server key 7 104506150E16060A2C557878 ! radius server HOTDELDC001 address ipv4 10.9.22.250 auth-port 1812 acct-port 1813 key 7 01180908500A120E011D1C5A ! radius server ITCHTLWELAVPAT address ipv4 10.9.22.25 auth-port 1812 acct-port 1813 key 7 01180908500A120E011D1C5A ! ! ! control-plane service-policy input system-cpp-policy ! ! line con 0 stopbits 1 line aux 0 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! call-home ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications. contact-email-addr sch-smart-licensing@cisco.com profile "CiscoTAC-1" active destination transport-method http ! ! ! ! ! ! end ------------------------------------------------------------------------------------------------------------------------------------ SERVERROOM#sh vlan br VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Gi1/0/2, Gi1/0/10, Gi1/0/11 Gi1/0/12, Gi1/0/13, Gi1/0/14 Gi1/0/18, Gi1/0/25, Gi1/0/30 Gi1/0/38, Gi1/0/39, Gi1/0/40 Gi1/0/41, Gi1/0/42, Gi1/0/43 Gi1/0/44, Gi1/0/45, Gi1/0/46 Gi1/0/47, Gi1/0/48, Te1/1/1 Te1/1/2, Te1/1/3, Te1/1/4 2 Microsense_PMS active 11 Finance active Gi1/0/19, Gi1/0/20, Gi1/0/21 Gi1/0/22, Gi1/0/23, Gi1/0/24 12 Engineering active Gi1/0/31, Gi1/0/32, Gi1/0/33 Gi1/0/34, Gi1/0/35, Gi1/0/36 Gi1/0/37 13 FrontOffice active 14 SixSigma active 15 GMO active 16 HK active Gi1/0/26, Gi1/0/27, Gi1/0/28 Gi1/0/29 17 HR active Gi1/0/1, Gi1/0/3, Gi1/0/4 VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- Gi1/0/5, Gi1/0/6, Gi1/0/7 Gi1/0/8, Gi1/0/9, Gi1/0/15 Gi1/0/16, Gi1/0/17 18 Banquet active 20 VLAN0020 active 22 VLAN0022 active 50 VC active 1002 fddi-default act/unsup 1003 token-ring-default act/unsup 1004 fddinet-default act/unsup 1005 trnet-default act/unsup ------------------------------------------------------------------------------------------------------- SERVERROOM#sh ip int br Interface IP-Address OK? Method Status Protocol Vlan1 10.9.22.15 YES manual up down GigabitEthernet0/0 unassigned YES unset administratively down down GigabitEthernet1/0/1 unassigned YES unset down down GigabitEthernet1/0/2 unassigned YES unset down down GigabitEthernet1/0/3 unassigned YES unset down down GigabitEthernet1/0/4 unassigned YES unset down down GigabitEthernet1/0/5 unassigned YES unset down down GigabitEthernet1/0/6 unassigned YES unset down down GigabitEthernet1/0/7 unassigned YES unset down down GigabitEthernet1/0/8 unassigned YES unset down down GigabitEthernet1/0/9 unassigned YES unset down down GigabitEthernet1/0/10 unassigned YES unset down down GigabitEthernet1/0/11 unassigned YES unset down down GigabitEthernet1/0/12 unassigned YES unset down down GigabitEthernet1/0/13 unassigned YES unset down down GigabitEthernet1/0/14 unassigned YES unset down down GigabitEthernet1/0/15 unassigned YES unset down down GigabitEthernet1/0/16 unassigned YES unset down down GigabitEthernet1/0/17 unassigned YES unset down down GigabitEthernet1/0/18 unassigned YES unset administratively down down GigabitEthernet1/0/19 unassigned YES unset down down GigabitEthernet1/0/20 unassigned YES unset down down GigabitEthernet1/0/21 unassigned YES unset down down GigabitEthernet1/0/22 unassigned YES unset down down GigabitEthernet1/0/23 unassigned YES unset down down GigabitEthernet1/0/24 unassigned YES unset down down GigabitEthernet1/0/25 unassigned YES unset down down GigabitEthernet1/0/26 unassigned YES unset down down GigabitEthernet1/0/27 unassigned YES unset down down GigabitEthernet1/0/28 unassigned YES unset down down GigabitEthernet1/0/29 unassigned YES unset down down GigabitEthernet1/0/30 unassigned YES unset down down GigabitEthernet1/0/31 unassigned YES unset down down GigabitEthernet1/0/32 unassigned YES unset down down GigabitEthernet1/0/33 unassigned YES unset down down GigabitEthernet1/0/34 unassigned YES unset down down GigabitEthernet1/0/35 unassigned YES unset down down GigabitEthernet1/0/36 unassigned YES unset down down GigabitEthernet1/0/37 unassigned YES unset down down GigabitEthernet1/0/38 unassigned YES unset down down GigabitEthernet1/0/39 unassigned YES unset down down GigabitEthernet1/0/40 unassigned YES unset down down GigabitEthernet1/0/41 unassigned YES unset down down GigabitEthernet1/0/42 unassigned YES unset down down GigabitEthernet1/0/43 unassigned YES unset down down GigabitEthernet1/0/44 unassigned YES unset down down GigabitEthernet1/0/45 unassigned YES unset down down GigabitEthernet1/0/46 unassigned YES unset down down GigabitEthernet1/0/47 unassigned YES unset down down GigabitEthernet1/0/48 unassigned YES unset down down Te1/1/1 unassigned YES unset down down Te1/1/2 unassigned YES unset down down Te1/1/3 unassigned YES unset down down Te1/1/4 unassigned YES unset down down _____________________________________________________________________________________________________________________
0 Replies 0
