Issues upgrading C9300x-24Y from 17.05.01 to 17.09.04a
RookieNet55
Hey everyone,
I have a brand new C930xx-24Y switch that I am trying to upgrade.
Current version of the switch
Switch Ports Model              SW Version        SW Image              Mode
*    1 54    C9300X-24Y         17.05.01          CAT9K_IOSXE           INSTALL
On checking in the website I notice there are two sub variants of this switch
C9300X-24Y-A
C9300X-24Y-E
I couldn't find which sub variant is my switch model, so I assumed it to be C9300X-24Y-E and then downloaded the below image
cat9k_iosxe.17.09.04a.SPA.bin
I am using the below procedure mentioned in this release notes
I am getting an error in the 4th step
Switch#install add file flash:cat9k_iosxe.17.09.04a.SPA.bin activate commit
install_add_activate_commit: START Thu Jan 18 14:40:16 UTC 2024
FAILED: install_add_activate_commit : flash:cat9k_iosxe.17.09.04a.SPA.bin is not valid file or cannot be handled by install CLI.
The release notes doesn't mention about 17.09.04a in the software images, should I first try 17.09.04 and then upgrade again to 17.09.04a ?
Kindly request some assistance with this. Thank you in advance for all the help.
7 Replies 7
matthew2587
Can you show dir flash:
@matthew2587 here is the output
Directory of flash:/
245761  drwx             4096  Jan 18 2024 14:40:24 +00:00  .installer
180227  -rw-          2097152  Jan 18 2024 14:34:25 +00:00  nvram_config_bkup
180226  -rw-          2097152  Jan 18 2024 14:34:25 +00:00  nvram_config
180251  -rw-       1251579379  Jan 18 2024 14:29:37 +00:00  cat9k_iosxe.17.09.04a.SPA.bin
180241  -rw-          5242880  Jan 17 2024 19:22:59 +00:00  ssd
180253  -rw-              616   Jan 3 2024 17:54:03 +00:00  vlan.dat
245764  drwx             4096  Nov 26 2023 20:43:17 +00:00  pnp-tech
180249  -rw-                0  Nov 26 2023 19:08:52 +00:00  dope_hist
180248  -rw-               89  Nov 26 2023 19:08:52 +00:00  rdope.log
180247  -rw-            14756  Nov 26 2023 19:08:52 +00:00  rdope_out.txt
180244  -rwx             2049  Nov 26 2023 19:07:20 +00:00  svl_ipc.tcl
180243  -rw-           134935  Nov 26 2023 19:07:20 +00:00  memleak.tcl
180242  -rw-              393  Nov 26 2023 19:07:15 +00:00  boothelper.log
327713  drwx             4096  Nov 26 2023 19:07:14 +00:00  dc_profile_dir
180240  -rw-              185  Nov 26 2023 19:07:03 +00:00  bootloader_evt_handle.log
286721  drwx             4096  Jan 11 2022 09:20:27 +00:00  .prst_sync
245763  drwx             4096  Jan 11 2022 09:10:45 +00:00  .dbpersist
180252  -rw-             1441  Jan 11 2022 09:02:32 +00:00  2022_01_11T09_02_02.416100.xml
253953  drwx             4096  Jan 11 2022 08:55:22 +00:00  core
393217  drwx             4096  Jan 11 2022 08:55:05 +00:00  guest-share
385025  drwx             4096  Jan 11 2022 08:55:03 +00:00  pnp-info
368641  drwx             4096  Jan 11 2022 08:55:02 +00:00  onep
352264  drwx             4096  Jan 11 2022 08:46:27 +00:00  .rommon_sync
180246  -rwx             1338  Jan 11 2022 08:46:25 +00:00  DigiCertGlobalRootCA.ca
352257  drwx             4096  Jan 11 2022 08:46:24 +00:00  Tbot
335873  drwx             4096  Jan 11 2022 08:46:23 +00:00  fp_cc_crash
327715  drwx             4096  Jan 11 2022 08:46:23 +00:00  sys_report
327681  drwx             4096  Jan 11 2022 08:46:22 +00:00  tech_support
311297  drwx             4096  Jan 11 2022 08:46:20 +00:00  ss_disc
303105  drwx             4096  Jan 11 2022 08:46:15 +00:00  .rollback_timer
180239  -rw-         47457458  Jan 11 2022 08:43:57 +00:00  cat9k-rpboot.17.05.01.SPA.pkg
180238  -rw-             6465  Jan 11 2022 08:43:57 +00:00  packages.conf
180237  -rw-             9220  Jan 11 2022 08:43:57 +00:00  cat9k-wlc.17.05.01.SPA.pkg
180236  -rw-         15934468  Jan 11 2022 08:43:57 +00:00  cat9k-webui.17.05.01.SPA.pkg
180235  -rw-         31306760  Jan 11 2022 08:43:57 +00:00  cat9k-srdriver.17.05.01.SPA.pkg
180234  -rw-         60109828  Jan 11 2022 08:43:57 +00:00  cat9k-sipspa.17.05.01.SPA.pkg
180233  -rw-         37098504  Jan 11 2022 08:43:57 +00:00  cat9k-sipbase.17.05.01.SPA.pkg
180232  -rw-        664237060  Jan 11 2022 08:43:57 +00:00  cat9k-rpbase.17.05.01.SPA.pkg
180231  -rw-             9220  Jan 11 2022 08:43:56 +00:00  cat9k-lni.17.05.01.SPA.pkg
180230  -rw-          2094088  Jan 11 2022 08:43:56 +00:00  cat9k-guestshell.17.05.01.SPA.pkg
180229  -rw-        109102088  Jan 11 2022 08:43:56 +00:00  cat9k-espbase.17.05.01.SPA.pkg
180228  -rw-         18301964  Jan 11 2022 08:43:56 +00:00  cat9k-cc_srdriver.17.05.01.SPA.pkg
I had the same issue with either the "A" or "E" download recently. I went with the "A" and it worked perfectly so you might try that.
Once I downloaded the A version that worked.
Try this command:
request platform software package install switch all file flash:cat9k_iosxe.17.09.04a.SPA.bin on-reboot new auto-copy verbose
Once I downloaded the version from C9300x-24Y-A version that worked fine. Not sure what is the difference though.
E & A defines the licensing model, A represents Advantage which has extra features compare to E (Essential).
refer below matrix
Enterprise Networks Software Subscription Matrix for Switching - Cisco
