03-01-2023 04:53 AM
i have a problem with c9200L stack,
Sometimes a port is blocked randomlly for one user and not for others, sometimes a hole vlan is blocked.
What i do is unblug the user and put the same configuration in another port or just make default configuration in the same port and reconfigure it with same config, or i shutdown the hole stack( taking off the alimentation).
I upgraded the version to the latest and it didn't resolve the problem, the ip phones gives the tftp problem.
03-01-2023 06:24 AM - edited 03-01-2023 06:25 AM
when port is blocks, check the reason for blocking.
1. check interface using #sh interface gi0/x and find the reason for blocking (err-disables)
2. check logs to understand why port/vlan is getting blocked
03-01-2023 09:26 AM
". . . the ip phones gives the tftp problem."
Which is?
03-01-2023 02:44 PM
When this happens again, post the complete output to the command "sh interface status err".
03-01-2023 03:24 PM
what version did you upgrade to? what is the configuration of the access port ?
Sometimes a port is blocked randomly for one user and not for others, sometimes a hole vlan is blocked. - BLOCK means, is the port go error disabled ? what reason ? if the whole VLAN - then I suspect some STP issue here ?
