nx-os command to view all interface input and output rate
zulfikhar2000
Is there a way in nx-os where I can view all interface input and output rate, so that I dont have to go each interface & check ?
6 Replies 6
try below
#sh inter | inc rate
Good luck
KB
This doesn’t help…If the switch have 100 ports we can’t trace…
True, but as MHM added, possibly you just need to further refine your regex.
(PT) e.g.:
Router#sh int | include (is down)|(rate)
GigabitEthernet0/0/0 is administratively down, line protocol is down (disabled)
Queueing strategy: fifo
GigabitEthernet0/0/1 is administratively down, line protocol is down (disabled)
GigabitEthernet0/0/2 is administratively down, line protocol is down (disabled)
Vlan1 is administratively down, line protocol is down
Cisco's regex.
I try
show interface | include input , output, and rate
all show the rate but the problem not show interface for each line.
if you dont want interface number then | inlcude is ok if not
please mention that and I will make deep dive.
thanks
thiru.vel10
Capture the output show interface and filter using Grep tool
 show interface e4/1 , e4/2 | i Ethernet4|rate <<- I found this command try it
thanks
