C9300-NM-4M module to 10Gig connection don't work properly
We connected two C9300 switches using Cat6a cable one has c9300-NM-4M Mgig module and another one is using 10 Gig Uplink however ports didn't up. when we try to connect switches between Mgig module and 1 Gig Ethernet port, It works fine.
Does anyone know why the connection between the module to 10 Gig uplink doesn't work properly?
Switch Version : 17.05.01
Module : c9300-nm-4m
Switch Model c9300-48t-e
We solved the issue.
-9300-48T with C9300-NM-4M modules not working properly with IOS-17.5.1
- But we downgrade the devices to17.3.4 version, they worked properly.
Thanks for help
6 Replies 6
balaji.bandi
You mentioned one side - c9300-nm-4m, what about other side? Normal 10GB Ethernet? what model other side ?
information help you : (post the interface configuration) :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_01001.html
BB
Sorry for confusion.
- connecting both side with c9300-NM-4M module
-and there is no configuration on switches.
by default ports may be in shutdown mode (admin shutdown)
can you post from both the side
show interface ten 1/1/1 (what ever interface you connecting)
BB
it works fine with 1 Gig port.
post the information as suggest to understand better.
BB
Thanks for help
