08-10-2023 04:51 AM
hello,
i have C9300-24UX with C9300-NM-8X, version 17.06.02
for some reason i cannot use any of the interfaces te1/1/1-4 ?
i test the same infrustructure with the same sfp+ at port te1/1/5 and everything works fine .... (SFP-10GBase-SR), also make a cold reboot with no success
any idea ? someone ?
thanks
08-10-2023 05:12 AM - edited 08-10-2023 05:17 AM
Hello @nir-quirk01,
When you insert SFP+ on te 1/1/1, does C9300 recognize SFP module?
Do you try to update the firmware or test the NM module on an other C9300?
08-10-2023 06:48 AM
actually i have replace the nim and same thing hapend,
but strange thing happend when i tried 1gig sfp over the problematic interfaces,
it came out that interfaces te/1/1/2 and 1/1/3 returen to work even with the sfp+
so it seems that right now te 1/1/1 and 1/1/4 stuck on the same issue
next thing for me is to upgrade the version to 17.06.05 that is the recommanded by cisco
08-10-2023 07:26 AM - edited 08-10-2023 07:26 AM
Yes for that upgrade ! @nir-quirk01
11-05-2023 02:49 AM
Hi, i have the same issue with Te1/1/1 did the IOS upgrade solve the issue ?
11-05-2023 04:02 AM
