C9300 - Trunked EtherChannel issues
lucy.bettison
Currently trying to configure two HP C7000 Chassis ports bundled into one EtherChannel, trunking multiple VLANs on a Cat9300
When we configure the interfaces with channel-group 10 mode on, both links come up bundled into the port channel but the hosts on the VM side are inaccessible.
When we configure the interfaces with channel-group 10 mode active, one interfaces goes suspended and one stays up and bundled.
The HP config is very basic and only used VLAN tagging and the LACP seems to be set and the timer set to short.
Group: 10
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Te1/1/7
Port state = Up Mstr Assoc In-Bndl
Channel group = 10 Mode = Active Gcchange = -
Port-channel = Po10 GC = - Pseudo port-channel = Po10
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Te1/1/7 SA bndl 32768 0xA 0xA 0x13C 0x3D
Partner's information:
Port Flags Priority Dev ID Age key Key Number State
Te1/1/7 FA 1 0409.7386.39cd 4s 0x0 0x4 0x21 0x3F
Age of the port in the current state: 0d:00h:30m:01s
Port: Te2/1/7
Port state = Up Cnt-bndl Suspend Mstr Not-in-Bndl
Port-channel = null GC = - Pseudo port-channel = Po10
Local information:
Te2/1/7 FA susp 32768 0xA 0xA 0x23C 0xF
Te2/1/7 FA 1 0409.7386.2991 0s 0x0 0x5 0x21 0xF
Age of the port in the current state: 0d:00h:29m:58s
Port-channels in the group:
Port-channel: Po10 (Primary Aggregator)
Age of the Port-channel = 1d:01h:25m:24s
Logical slot/port = 35/10 Number of ports = 1
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Te1/1/7 Active 0
Time since last port bundled: 0d:00h:30m:01s Te1/1/7
Time since last port Un-bundled: 0d:00h:30m:04s Te2/1/7
16 Replies 16
Don't have a switch in the HP side. They just use Shared Uplink Sets.
anyway now you know why the bundle not form, the HP use different Dev-ID and Dev-ID need by Cisco to know that this port is for this port-channel and that port is for other port-channel.
and why it accept with Mode ON because Mode ON no read this detail it put port to port-channel and later you will face issue like yours "no connectivity".
