11-07-2022 07:56 AM
What happens if I give transport output command?
11-07-2022 08:24 AM
transport output telnet - telnet can be initiated from this device, so if you were going to use it as a terminal server
11-07-2022 08:28 AM
Sw1-sw2
You telnet first to sw1
Then inside sw1 you will telnet sw2
Here you need output.
11-07-2022 08:28 AM
if you give that command on VTY Lines, from that device you able to connect to other devices.
if other device has no ACL
