C9300 Web UI issue (page does not load)
Ingénierie RCI
Hi everyone,
I installed two stacks of C9300-24UX (2 member in each stack) in 17.3.4 version. I made the configuration in CLI mode and everything was fine.
But on the Web UI I'm facing an issue with some menu. The page load indefinitely and I can't acces to settings. For example, this issue appears on interface menu (as you can see on the attached screenshot).
I found this post on bug search tool : Bug Search Tool (cisco.com)
I've trie to increase VTY line but nothing changed.
Anybody has an idea ?
Many thanks
Best regards
7 Replies 7
balaji.bandi
how about other browser Like FF or IE
BB
Thanks for your answer.
I've tried different browsers but nothing changes.
I forgot to specify the firmware version. The switches are in 17.3.4
is this device activated License.
as per the Day 0 setup : Configuring VTY Lines ( you mentioned you did this change, have you reloaded the device and tested ?)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-3/configuration_guide/b-173-9300-cg/b-173-9300-cg_chapter_010.html
save and reload and test it.
BB
I made the link between Switches and Cisco Software Central if is what you mean by "activated license" ?
Yes when I tried this option, I reloaded the switch. Last time, I mades changes in CLI, maybe should I try again in Web UI ?
do you get the same errors when you use http instead of https ? Try and disable https (no ip http secure-server) and check what the results are.
Or disable both http and https:
no ip http server
reboot the switch, and the re-enable both:
ip http server
I will test your solution as soon as possible. I can't try it now because switches are installed at the end customer and are still running.
I'll keep you informed of results.
I tried to disable HTTPS and used HTTP but I faced the same issue.
I couldn't reboot the switch because it wase in working hour.
Maybe I'lle try it one day if I set an appointment with my customer !
I'll keep you informed.
Best regards
