C9407 show power incorrect
fhk-cwempe
I wanted to check how much power our new Catalyst 9407 is consuming.
The switch is configured and running.
There is only one Access Point connected. No other clients.
#sh power
Power                                                       Fan States
Supply  Model No              Type  Capacity  Status        1     2
PS1     C9400-PWR-3200AC      ac    3200 W    active        good  good
PS2     C9400-PWR-3200AC      ac    n.a.      faulty        good  good
PS3     C9400-PWR-3200AC      ac    n.a.      faulty        good  good
PS4     C9400-PWR-3200AC      ac    n.a.      faulty        good  good
PS Current Configuration Mode : Combined
PS Current Operating State    : Combined
Power supplies currently active    : 1
Power supplies currently available : 1
Power Summary          Maximum
 (in Watts)    Used    Available
System Power   1535    1535
Inline Power   25      1665
Total          1560    3200
But I think the "used System Power" should not be 1535 Watt for an idle switch.
Actually, I measured the power consumption is about 400 Watt.
Am I interpreting this wrong?
Can anybody reproduce this?
Is this a bug? (Cisco IOS XE Software, Version 17.03.03)
5 Replies 5
balaji.bandi
If you are inspected Physically all good, try to reseat the PSU and see if that fix the issue
then it is a bug in the new code, Raise TAC case.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm55520/?rfs=iqvred
BB
The issue existed in 16.09.04, too.
I rebooted and updated today.
I will check if completely disconnecting from power (or how do I reset the PSU?) will help.
i corrected  the mistake i mean reseat PSU.
BB
Reza Sharifi
I think those are the correct numbers. here is an output from a 9410 with one port connected to it
System Power 1870 1870
Inline Power 0 4530
Total 1870 6400
My older Catalysts (e.g. Catalyst 4507R+E) show a lower "used System Power" than the "Maximum Used Available".
#sh pow
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-4200ACV   AC 4200W   good         good     good
PS1-1                         220V   good
PS1-2                         220V   good
PS2     PWR-C45-4200ACV   AC 4200W   good         good     good
PS2-1                         220V   good
PS2-2                         220V   good
Power supplies needed by system    : 1
Power supplies currently available : 2
System Power (12V)        704        1360
Inline Power (-50V)       328        3456
Backplane Power (3.3V)     40          40
Total                    1072 (not to exceed Total Maximum Available = 4200)
Power Measurement    Inline Power (-50V)
(in Watts)             (+/- 50Watts)
PS1                         100
PS2                         100
Total                       200
