C9500-16X unable to take remote session(SSH) and slow perfomance
kindly help me out on this issue..unable to perform SSH and the console is working-and very slow performance as well.
C9500-16X 16.12.3a CAT9K_IOSXE INSTALL
balaji.bandi
C9500-16X 16.12.3a
This little bit of bug, try to go upper code were possible like 17.3.X
Thre are 2 issues, 1 is slow another 1 ssh, let's look both in different
1. SSH have you setup ssh config ( so post-show run from here)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-11/configuration_guide/sec/b_1611_sec_9500_cg/configuring_secure_shell__ssh_.html
2. Slow in the console ? depends on terminal emulators.
BB
Slowness means not only during the console access entire performance is very slow, as you said that could be bug issue due to old ios version.
for the SSH issue do you require any logs to analyze?
1. SSH have you setup ssh config ( so post-show run here)
check
show ip ssh
check VTY lines configured
as i pointed post  (config here - issue a command show run
BB
