WAN redundancy
Tuckertimmy
Hello everyone,
I'm tasked with finding the best way to add redundancy to our two data centers.
Data center A is the main data center, and has an internet connection.
Data center B is primarily a WAN backup with no internet connection, but has the majority of our servers.
The Edge configuration (outside -> in):
     ISP
     Outside switches
     HA pair firewalls
     Inside switches
     Router for Data center A
     Router for Data center B is reachable via core 7Ks
          Data center A's router and data center B's router are also connected via point-to-multipoint circuits
The only way to reach the internet for both Data centers is through the router at Data center A.
If the router at Data center A is not available (down or maintenance) there is no internet access (Oh, I forgot to mention that this is a hospital, and that is greatly frowned upon).
I'm thinking about connecting Data center B's router to the Inside switches.
     (there is a fiber-ring in this part of the city that allows me direct fiber connection)
this will give Data center B internet access, but I do not want it to have internet access unless Data center A's router is unreachable
What is the best switch configuration to obtain this?
I'm proposing to connect Router B to the Inside switches
But only as a failover when Router A is unreachable
config
ASA
interface GigabitEthernet0/0
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
nameif Inside
security-level 100
ip address 192.168.1.5 255.255.255.224 standby 192.168.1.6
interface Redundant1
member-interface GigabitEthernet0/0
member-interface GigabitEthernet0/1
nameif Outside
security-level 0
ip address 1.1.1.112 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 1.1.1.1 1
route Inside 0.0.0.0 0.0.0.0 192.168.1.1 tunneled
nat (Inside,Outside) source dynamic any pat-pool PAT_POOL flat include-reserve round-robin
INS-SW-3850-1#
interface Port-channel1
description connection to INS-SW-3850-2
switchport mode trunk
interface Vlan100
ip address 192.168.1.3 255.255.255.224
interface GigabitEthernet1/0/39
description connection to primary sourcefire port 1 (OARnet)
switchport access vlan 100
switchport mode access
switchport port-security maximum 3
switchport port-security violation restrict
switchport port-security aging time 3
switchport port-security aging type inactivity
no logging event link-status
no snmp trap link-status
snmp ifindex persist
spanning-tree portfast trunk
spanning-tree link-type point-to-point
interface GigabitEthernet1/0/41
description connection to primary sourcefire port5 (Spectrum)
interface GigabitEthernet1/0/46
description Uplink to ASR1 int gi0/0/4
spanning-tree bpduguard enable
spanning-tree guard root
interface GigabitEthernet1/0/47
description uplink to Edge-Block-2 (rack Edge 1, RU27) int Gi0/47 (member of Po1)
channel-group 1 mode active
interface GigabitEthernet1/0/48
description uplink to Edge-Block-2 (rack Edge 1, RU27) int Gi0/48 (member of Po1)
ip default-gateway 192.168.1.1
ASR#
interface GigabitEthernet0/0/4
description *** to Primary Inside Switch ***
backup interface GigabitEthernet0/0/5
ip flow monitor MONITOR output
ip address 192.168.1.2 255.255.255.224
ip wccp 91 redirect in
ip wccp 96 redirect in
ip pim sparse-mode
standby 1 ip 192.168.1.1
standby 1 priority 200
standby 1 preempt
delay 10
negotiation auto
end
description *** to Secondary Inside Switch ***
ip address 192.168.1.10 255.255.255.224
ip pim sparse-mode
standby 1 preempt
delay 10
negotiation auto
end
7 Replies 7
Reza Sharifi
The issue with this design is that you are relying on one router and one service provider for Internet access. A better design would be to have one router in each location with its own Internet access using different service providers. For example; site A would have its own Internet access using ISA-A (primary) and will use site-B as backup Internet access with its own ISP (ISP-B). This way for example, if the provider on A site has a maintenance window, a fiber cut, a power outage, etc., you simply shift all your traffic to B site, or if the router on A site fails, all traffic would be rerouted to B site. Hospital networks are 24x7 and very critical, so you really want to have the most redundant design in place.
A much better design would be to have 2 different SPs connecting to 2 different routers in each location.
Tuckertimmy
I would agree, but this is what I have to work with.
Until they integrate another ISP at Data center B, I have to find the best way to configure things as they are.
I understand.
If Internet access is the highest priority, I would at least have 2 routers in location A connecting to 2 different providers until they can integrate another ISP at data center B. This will give you local redundancy in case of an ISP outage, problem (which is not uncommon), or a router failure.
There are plenty of ways to establish redundancy to reach the internet. Could you provide a basic drawing from internet to switches that you want to configure?
so basically if Router B cannot reach Router A, the next hop for Router B should be the firewall pair ? That should be fairly easy to accomplish by using an IP SLA. Can you post the configuration of Router B ? Put a description on the interfaces that connect to Router A and the inside switches.
Hello
Given your current setup this is the most applicable option, but you shouldn't have to wait for a router A to fail to manually do this, it may be possible to setup this up in dynamic way.
If you could physically attach Router B into the inside switch's (maybe via the 7ks) and depending on your current routing design it may be possible to traffic engineer route metrics so as/when router A loses reachability to the internet, route forwarding for DCB would converge via rtr B towards your internet circuits.
It could be as simplistic as appending conditional default route to router B so it only uses this default route as/when router A loses reachability to the internet, this could be accomplished with IPSLA and object tracking or even a EEM script, this should then provide some degree of internet resiliency, however without knowing how you have routing setup its hard to provide a viable solution.
Kind Regards
Paul
It involves the interconnection of multiple WAN links onto one or more SDN (software-defined networking) devices. The SDN device employs algorithms to appropriately distribute WAN traffic across all links, which results in both load balancing and redundancy. Multiple WAN connection scenarios. Seehttps://community.cisco.com/t5/network-security/query-regarding-result-bfd/td-p/1493452
