C9500-24Y4C-A SVL(Stackwise Virtual Link) not running as 25G
bmi_loochemy
In the past I have 2 units C9500-24Y4C-A running IOS 16.9.4. the SVL(Stackwise Virtual Link) between both 25G x2.
so total 50G
As below
MY01-NSW30-CORE-OT#sh stackwise-virtual link
Stackwise Virtual Link(SVL) Information:
Flags:
Link Status
U-Up D-Down
Protocol Status
S-Suspended P-Pending E-Error T-Timeout R-Ready
Switch SVL Ports Link-Status Protocol-Status
1 1 TwentyFiveGigE1/0/23 U R
TwentyFiveGigE1/0/24 U R
2 1 TwentyFiveGigE2/0/23 U R
TwentyFiveGigE2/0/24 U R
MY01-NSW30-CORE-OT#sh stackwise-virtual bandwidth
Switch Bandwidth
1 50G
2 50G
But.... recent purchased of C9500-24Y4C-A & C9500-48Y4C-A running on IOS 17.03.03, the SVL only 10G, with 2 link total 20G only.
MY01-NSW10-B03L2-DIST#show stackwise-virtual link
Flags:
Link Status
U-Up D-Down
Protocol Status
1 1 TwentyFiveGigE1/0/47 U R
TwentyFiveGigE1/0/48 U R
2 1 TwentyFiveGigE2/0/47 U R
TwentyFiveGigE2/0/48 U R
MY01-NSW10-B03L2-DIST#show stackwise-virtual bandwidth
Switch Bandwidth
1 20G
2 20G
What Happen?
5 Replies 5
balaji.bandi
Not that i aware of this big change should go up with the latest firmware not degrade, before getting in too deep of the issue
i would first physically investigate, what kind of SFP modules installed on new switches on port  1/0/47 and 2/0/47 by issue command
show interface tw 1/0/47 trans details
show interface tw 2/0/47 trans details
BB
Sorry above is C9500-48Y4C-A using Cisco "SFP-10G-LR-S" singlemode fiber
Below is another stack using details C9500-24Y4C-A with SFP-10G-SR multimode fiber OM4. same IOS version 17.3.3
MY01-NSW10-B12L1-DIST#sh int Twe1/0/24 trans detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Twe1/0/24 34.5 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Twe1/0/24 3.34 3.63 3.46 3.13 2.97
Current Threshold Threshold Threshold Threshold
Port Lane (milliamperes) (mA) (mA) (mA) (mA)
Twe1/0/24 N/A 6.7 10.0 8.5 3.0 2.6
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port Lane (dBm) (dBm) (dBm) (dBm) (dBm)
Twe1/0/24 N/A -2.3 1.7 -1.3 -7.3 -11.3
Receive Power Threshold Threshold Threshold Threshold
Twe1/0/24 N/A -2.3 2.0 -1.0 -9.9 -13.9
MY01-NSW10-B12L1-DIST#sh int Twe2/0/24 trans detail
Twe2/0/24 36.1 75.0 70.0 0.0 -5.0
Twe2/0/24 3.34 3.63 3.46 3.13 2.97
Twe2/0/24 N/A 6.4 10.0 8.5 3.0 2.6
Twe2/0/24 N/A -1.9 1.7 -1.3 -7.3 -11.3
Twe2/0/24 N/A -2.1 2.0 -1.0 -9.9 -13.9
NAME: "TwentyFiveGigE2/0/23", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR , VID: V03 , SN: JUS1737G29X
NAME: "TwentyFiveGigE2/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR , VID: V03 , SN: JUS1739G0EC
NAME: "TwentyFiveGigE1/0/23", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR , VID: V03 , SN: JUS1738G1FW
NAME: "TwentyFiveGigE1/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR , VID: V03 , SN: JUS1739G0DN
MY01-NSW10-B12L1-DIST#sh stackwise-virtual link
Flags:
Link Status
U-Up D-Down
Protocol Status
MY01-NSW10-B12L1-DIST#sh stackwise-virtual bandwid
MY01-NSW10-B12L1-DIST#sh stackwise-virtual bandwidth
Switch Bandwidth
1 20G
2 20G
MY01-NSW10-B12L1-DIST#sh ver
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.3, RELEASE SOFTWARE (fc7)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Thu 04-Mar-21 12:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.3.1r[FC2], RELEASE SOFTWARE (P)
MY01-NSW10-B12L1-DIST uptime is 51 minutes
Uptime for this control processor is 53 minutes
System returned to ROM by PowerOn at 11:34:50 MYT Tue May 11 2021
System restarted at 09:55:18 MYT Wed May 12 2021
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9500-24Y4C (X86) processor with 2904385K/6147K bytes of memory.
Processor board ID FDO24410XMK
7 Virtual Ethernet interfaces
48 TwentyFive Gigabit Ethernet interfaces
8 Hundred Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16002876K bytes of physical memory.
11161600K bytes of Bootflash at bootflash:.
1638400K bytes of Crash Files at crashinfo:.
11161600K bytes of Bootflash at bootflash-2:.
1638400K bytes of Crash Files at crashinfo-2:.
Base Ethernet MAC Address : dc:77:4c:19:a5:00
Motherboard Assembly Number : 4874
Motherboard Serial Number : FDO24410XMK
Model Revision Number : V02
Motherboard Revision Number : 2
Model Number : C9500-24Y4C
System Serial Number : FDO24410XMK
Switch 02
Base Ethernet MAC Address : dc:77:4c:19:a6:40
Motherboard Serial Number : FDO24410XLX
System Serial Number : FDO24410XLX
"SFP+ 10GBASE-SR"
You have 10G SFP, you looking that become 25GB is this possible ? (its not)
you need to buy 25GB SFP optic Module for the port to support 25GB, then you see 50GB. - this not an issue with hardware.
you have lower SFP which show you 20GB that is correct.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/datasheet-c78-736950.html
BB
Deepak Kumar
If I am not reading incorrectly, You are using an SFP module "SFP-10G-SR" and its data rate is 10G only. So the mentioned output is correct. You have to upgrade your SFP modules.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
But then what to explain I have another old stack C9500-24Y4C running IOS 16.09.04.
I can use SFP-10G-LR to achieve 25G SVL.
Does it mean Cisco limit SFP+ on newer IOS?
