C9500 - TIMEOUT: CONN_ERR_CONN_TIMEOUT_ERR
shamg1974
Level 3
Level 3
I have two 9500's in virtual stackwise setup. Stackwise links are twe1/0/27 and 28. When I plug the 40Gb cable into 1/0/27 on switch 1, I get the following errors from console:
Jun 20 16:18:58.480: %NIF_MGR-6-PORT_CONNECTION_STATUS_CHANGE: Chassis 1 R0/0: nif_mgr: PORT:FortyGigabitEthernet Port 27 changed state from Ready to Timeout.
Jun 20 16:18:58.480: %NIF_MGR-6-PORT_CONN_TIMEOUT: Chassis 1 R0/0: nif_mgr: FortyGigabitEthernet Port 27 on front side stack link 0 connection has TIMEOUT: CONN_ERR_CONN_TIMEOUT_ERR
*** Standby not fully configured for switchover, reloading.
Jun 20 12:19:38.169: %PMAN-3-RELOAD_SYSTEM: R0/0: pman: Reloading: Chassis will be reloaded
Jun 20 12:19:39.554: %PMAN-3-RELOAD_SYSTEM: R0/0: pvp: Reloading: Other RP is not standby ready. System will be reloaded
 Chassis 2 reloading, reason - Reload command
When I take the cable out, I still have my stackwise up on 1/0/28. I've tried multiple 40Gb cables. I'm reading there was a bug regarding incorrect mac add setup in rommon (https://bst.cisco.com/bugsearch/bug/CSCvj43609?rfs=qvred), however, a show romvar shows the following mac add setup:
MLN-9500-CORE#sh romvar
Switch 1
ROMMON variables:
SWITCH_NUMBER="1"
MAC_ADDR="48:80:02:20:50:60"
I'm running version 17.09.05 which is the current gold star version and the above bug should have been resolved in previous versions to this one.
Any help on this is greatly appreciated!
Mark Elsen
        - If you are on a gold star version then you need to escalate the issue towards TAC ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
