CAB SFP 50 cm
ritazreiby
Hey,
i need to know if the CAB-SFP-50cm is compatible with the SFP ports in C3650-48PS-L and C3750X-24T-S ? and why wouldn' it work given that it works on SFP ports..
Thank you
No, it is not compatible with those switches.
"The Catalyst 3560 switch supports the SFP module patch cable, a 1/2 meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560 switches in a cascaded configuration"
The resean might be the type of transmiter in 3560.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/21268-132.html
Masoud
Ganesh Hariharan
Hey,i need to know if the CAB-SFP-50cm is compatible with the SFP ports in C3650-48PS-L and C3750X-24T-S ? and why wouldn' it work given that it works on SFP ports..Thank you
Hello ,
As per the compatibilty matrix of CAB-SFP-50m it is an alternative to using SFP transceivers when interconnecting Catalyst 3560 switches through their SFP ports.
Have a look in the below link .
CAB-SFP-50m compatibilty matrix
Hope it Helps..
-GI
Rate if it Helps..
