Cable Diagnostics Cisco 3650
Robert Falconer
What does the status 'Open' really mean? I read the documentation that says 'the pair of wires is open', which doesn't explain much.
Hope the below helps you
https://supportforums.cisco.com/document/74231/how-use-time-domain-reflectometer-tdr
Madhu
Hi Robert,
Has the above helped?
Do you require any more help?
Madhu
Leo Laohoo
Robert,
Your question is "loaded".  I will find it difficult to answer that question if I don't see the output to the command "sh cable tdr interface <BLAH>".
