calculate 4500E power
Jonn cos
Level 4
Level 4
Hi all,
Can someone pls tell me how to calculate ac power supply based on chassis and line cards ?
7 Replies 7
aukhadiev
you can use Cisco Power Calculator Tool:
http://tools.cisco.com/cpc/launch.jsp
i did but i dont know how to interpret it. How can i attach it to this post ?
Reply ---> Use advanced editor ---> Attach Files
Thanks alot,
I have attached the file, pls help me interpret it
Hi, Jonn...
  1. There is a good Power Calculator Tutorial/Q&A sections (link is located on the home page of Power Calculator Tool), they explain how the calculator derives the final power results
  2. Also very useful article - Power over Ethernet on the Cisco Catalyst 4500E Series Platform Data Sheet: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet09186a00801f3dd9.html
  3. Unambiguous answer, what PS you need is not... All depends on the continued growth...
  4. Based on your current configuration, the minimum PS in redundant mode is 1000W, but you have one empty slot for further growth and if you need in future the PoE 1000W PS not suitable (1000W and 1400W AC data-only PS). Perhaps a choice of power supplies whis support PoE will be more preferable - 1300W, 2800W or 4200W.
  5. Also keep in mind that 2800W PS  has 1400W for data and 1400W for PoE, 1300W and 4200W PS do not allocate a fixed amount of power for data and PoE
Sir pls tell me, how you deduced 1000W PS ?
please see highlighted item in green in the attached document...
It is important that it is not only the Minimum Power Supply,but still Single/Redundant... not Combined
