campus wide vlan
Timothy Burns
Just had a quick design question to get further insight on.
We have small enterprise campus with about 80+ switches. Currently we setup vlans per closet that are trunked back to the core and have vrf's per function and route between VRF's.
Example
Closet A
vlan 1 printers
vlan 2 PC
Vlan 3 cameras
Closet B
Vlan 11 printers
vlan 12 PC
vlan 13 cameras
Printer guy says he would like for all printers to be on the same vlan/subnet across the whole campus as it make it much easier for some of the applications he uses to talk to them. We have a print server and no direct printing.
I am going back and forth on this. The subnet we would need to support this would be quite small, /23 at the max. We have control of all printers so we can shut off any unneeded chatty protocols. Everything comes back to the core for routing as well.
The main downside I see is broadcast traffic. Which really should not be much as all as we can shut off anything we don't want.
Any suggestions either way?
Reza Sharifi
Putting all printers in the same vlan should not be an issue and should work fine.  Just let the printer/server guys know that if there is ever something wrong with the printer vlan, no one in the campus can print.
