VLAN Ip configuration problem
vishwajitroy
Community Member
Hi All
When I am trying to configure ip,no response from SG300 switch.Waiting continuously.Please help me ,how to solve this.wait.JPG
6 Replies 6
mohammed01701
Level 4
Level 4
Hi!
What are you trying to change? If you are changing from 192.168.1.0/24 to 10.10.2.0/24 you have to change also the pc you using to the new subnet 10.10.2.x/24 efter that you Will get some respons from THE switch.
/Mohammed
Thank you for your answer.I have not changed switch default ip (192.168.1.254).MY pc is 192.168.1.207.I need to configure vlan 10(10.10.2.0-untagged port 3&4) and vlan 20(192.168.5.2 -untagged port 5&6). I am able to assign port for vlan 10 and 20.But when I am trying to configure IP for both vlan 10 and 20,it is not working.Can you please tell me what to change.
Thank you again for your help.
By Default, SG300 switches are coming with L2 (Layer Mode) so you can configure only one IP per switch (one IP on any SVI). So it will overwrite the default IT address and not respond to you.
The best solution to convert in Layer 3 mode so you can configure multiple IPs on the switch (Different Subnet on Different SVI/Loopback).
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak I have changed the switch to Layer 3 mode.Can you please give the link for vlan configuration steps. thanks.
Here, I am sharing a link for your reference.
https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=67844b99e2da4a7f88db0c588197487d_Creating_VLANs_on_Cisco_Managed_Switches.xml
Deepak Kumar
Deepak Kumar,
Hello Deepak kumar
Thank you for your mail.I am facing the problem of IP configuration.I have untagged port 5 as access port to vlan 10.I am trying to configure ip 192.168.5.200 to VLAN 10.But it is not saving in switch.I have attached the screenshot for that.Please let me know what to change.
Thank you.
Roy
