Can DMZ be set up on same switch? Only have one 2960-S switch
davidbirchell
I need to set up a DMZ but do not have a second switch. Is this possible on the 2960-S switch configuring specific ports?
Jon Marshall
It's not clear without your topology but as a general answer yes you can create vlan on your 2960 switch and have the L3 interface for that vlan routed off the firewall. You must make sure that there is no L3 interface on a L3 switch for that vlan though.
That is, as i say, just a general answer though.
Jon
