07-06-2021 07:48 AM
I have two 24 port 9300's and a 48 port 9300. Can I combine these into one stack?
Solved! Go to Solution.
07-06-2021 08:26 AM
Models with different port counts, generally, isn't an issue.
Models with different IOS feature sets and/or different IOS versions can be.
07-06-2021 07:56 AM
yes you can do - make sure you check the models
07-06-2021 08:26 AM
07-06-2021 03:59 PM
1. Make sure the existing switch/stack and the new switch are running the same IOS-XE versions.
2. Make sure the existing switch/stack and the new switch are running either in Install Mode or Bundle Mode (and NOT BOTH).
3. 9300 and 9300L cannot be stacked together.
