06-09-2012
05:48 AM
- last edited on
03-25-2019
04:20 PM
by
ciscomoderator
hello,
i am trying to ping 172.16.0.250 address from my desktop located in vlan 10.
i can able to ping 172.16.0.250 from my L3 switch but not able to ping from my desktop belong to vlan 10.
we have assing 172.16.0.254 ip to one interface fa 0/48.
dekstop can able to ping 172.16.0.254 this ip.
pasting running config
CTC_L3#show run
Building configuration...
Current configuration : 4357 bytes
version 12.2
no service pad
hostname CTC_L3
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
crypto pki trustpoint TP-self-signed-2873386624
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2873386624
revocation-check none
rsakeypair TP-self-signed-2873386624
crypto pki certificate chain TP-self-signed-2873386624
quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 8
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 10
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
no switchport
ip address 172.16.0.254 255.255.248.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
ip directed-broadcast 1
interface Vlan8
ip address 172.16.8.1 255.255.254.0
interface Vlan9
ip address 192.168.9.1 255.255.255.0
interface Vlan10
ip address 172.16.10.1 255.255.254.0
ip default-gateway 172.16.0.250
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.250
ip route 172.16.0.11 255.255.255.255 172.16.0.250
ip route 172.16.0.250 255.255.255.255 FastEthernet0/48
ip route 192.168.11.0 255.255.255.0 172.16.0.250
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
CTC_L3#$
your help is highly appriciated.
06-10-2012 04:47 AM
Thanks guys for reply,
as per above post, i have created vlan same as my existing network (172.16.0.0/255.255.248.0) named vlan 1.
host belong to vlan 1 can able to ping my other host available in my existing networkk connected to plane switch.
but the host from vlan 8 and vlan 10 are not able to ping host available in my plane network. they can only able to ping the host of vlan 1 available in my l3 switch.
at the end of the day i need default route pointing to my firewall 172.16.0.250 for connecting to branches and internet.
the question is how do i advertised to have the intervlan routing???
i have already enable intervlan routing using ip routing command in layer 3 switch.
the excisting configuration is as below.
Press RETURN to get started.
Switch>
Switch>
Switch>en
Switch#show run
Current configuration : 4115 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip routing
quit
no switchport
no ip address
interface Vlan1
interface Vlan8
interface Vlan10
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
thanks
06-10-2012 05:56 AM
I would do the following.
L2(Switch) ---> L3(Switch) ---> Firewall ---> Internet
Have the link between the L2 switch and L3 switch be a trunk carrying the vlans you need or all, doesn't matter.
Make sure to specify who ports belong to which vlan on the L2 switch. I would then setup L3 intervlan routing on the
L3 switch. That way traffic will flow via L2, to the Default Gateway on the L3 switch, then following routing to specified
vlans or hit the default route and go out to the Internet. You're traffic flow, troubleshooting, and everything else will be
must easier.
06-10-2012 06:48 AM
Thanks John,
yes i aggreed with you this is a ideal solution is to have network like
but in my case i dont have sufficient resources to put aal netwrok computers in a vlan. so i am trying to separate atlease one network. so in future slowally i can migrate the other one also.
can we do something like this
what ever host not available in L3. destination to those address will broadcast to interface connected to plane switch.
or
some sort of source and destination based routing.
as of now from layer3 switch i can ping to all devices but from vlan 8 and vlan 10 it fail.
06-10-2012 07:14 AM
I keep forgetting you have a plain L2 switch. Well the L2 plain switch, is currently only in one broadcast domain which is 172.16.0.0/28. You have bi-directional intervlan communication of your vlans on the L3 switch, and you have 172.16.0.254 on the VLAN1 interface. You know that the switch can ping the firewall and other hosts on the L2 switch. Now, if the host on 172.16.0.0/28 network wants to communicate with a host on one of the vlans on the L3 switch, it will go to its default gateway which if it's 172.16.0.254, it should work. Because, it should have directly connected networks for the specific vlans that are terminated on that L3 switch.
06-10-2012 09:32 AM
soryy for confusion, my firewall ip add ress is 172.16.0.250 . my internal network 172.16.0.0/21 using firewall interface as an default gateway to send traffic outside (internet and branches). in above case i have to change gatway of my all client computer and server. in that case also traffic to internet will not pass becoase we will make 172.16.0.254 as our new default gateway.
please correct me incase i;m making some mistake.
06-10-2012 10:13 AM
Well if traffic from hosts on the L3 switch, reach the DR out 172.16.0.250(Firewall IP), and goes out on the internet, and then comes back, the L2 switch isn't going to have a route back to any of the networks on the L2 switch. The reason that it's working fine for hosts on 172.16.0.250 is, that switch is on that directly connected network(same vlan) will work fine.
06-11-2012 03:40 AM
thans John,
i have put route on my firewall to route a traffic having destination to vlan 8 should be point to my vlan 1.
plane switch client->gateway 172.16.0.250(firewall interface)->destination 172.16.8.0/23 (vlan 8 in L3)->forward to 172.16.0.254/21 (vlan 1 ip on L3)
using this i can not able to ping vlan 8 (172.16.8.1/23) but only problem is that i cannot able to ping the client connetce to vlan 8 (172.16.8.2/23)
any suggestion??
06-11-2012 03:44 AM
Switch#show run
Current configuration : 2335 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip routing
interface Vlan1
interface Vlan8
interface Vlan10
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
Switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.8.0/23 is directly connected, Vlan8
C 172.16.0.0/21 is directly connected, Vlan1
Switch#
06-11-2012 04:18 AM
I don't think you're going to have to much luck considering that the L2 switch can't do routing. Is the Plain switch a unmanaged dumb switch?
06-11-2012 04:55 AM
as of now i am not considering to do routing using l2 here i am using l3 switch.
we lan created on l3 once evey think is fine to extend the number of host i will connect l2 with l3 as a trunk.
as of now all host are conneted to the l3.
yes the plane switch is un managebale switch.
06-12-2012 11:17 PM
This is to inform you that i have manage to fix the problem.
After doing routing on my firewall destination to newlaly cretaed vlan. i can manager to ping gateway of vlan.
since the interface is directally connected with firewall vlan interface is pinging.
for desktop connected to vlan i have creted a filter rule in firewall. after that its working fine..
we can able to ping all rdevices from both direction.
06-13-2012 05:59 AM
I'm glad to hear it dipak. Getting it to work is always a good thing
Have a good one!
