can not connect to web based interface with SG350 using factory default IP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-04-2020 02:12 PM
I have a new SG350 that is in factory default using 192.168.1.254. I've connected it to my Mac and manually setup an IP 192.168.1.100 and a subnet of 255.255.255.0. When I open a web browser and enter 192.168.1.254 it does nothing..
Therefore, I can't connect to the web based interface for the switch. Why is this?
Any info would be awesome!
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:16 PM
If the Device factory opened you should be able to get that page.
couple of steps to check :
1. are you able to ping 192.168.1.254 ?
2. If not try setting up your Laptop DHCP enable see Switch can offer DHCP IP address ?
if both are not working. - worth reset to factory and start over.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:19 PM
Thanks. How do I ping on a Mac?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:21 PM
use this to go to command level (MAC or Linux called shaell)
https://support.apple.com/en-gb/guide/terminal/apdb66b5242-0d18-49fc-9c47-a2498b7c91d5/mac
once you have
#ping 192.168.1.254
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:31 PM
thank you again..
it's telling me command not found
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:33 PM
This is what it shows:
~ % #ping 192.168.1.254
zsh: command not found: #ping
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:47 PM - edited 11-04-2020 02:51 PM
try this
ping 192.168.1.254 ( with out # - this means you are command at prompt)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 02:35 PM
you can use the below document GUI tool (ping tab)
