can not ping virtual ip of HSRP in switch2 wtih DynamipsGUI
mar.stanley
Router 1 and Switch 1 form HSRP group
can not see virtual mac address with sh ip arp
https://skydrive.live.com/redir?resid=E0ED7271C68BE47C!212
another thing i discover only using f0/0 and f0/1 of switch2 to connect others can make
both reconignize active and standby
when using f0/0 and f1/0 of switch2, there will be two active, they can not recognize. Why?
After set all ports in whole topology duplex full and speed 100
Switch2#sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.16.0.254 0 Incomplete ARPA
Internet 172.16.0.4 - cc00.0d94.0000 ARPA Vlan1
Switch2#sh ip arp
Switch2#sh ip arp
it has appear but then disappear
router1
f0/0
f0/0
switch2 f0/1 -- f0/0 switch1
config t
hostname Router1
int f0/0
ip address 172.16.0.2 255.255.0.0
no shutdown
end
config t
int f0/0
speed 100
duplex full
end
config t
hostname Switch1
int f0/0
no switchport
ip address 172.16.0.3 255.255.0.0
no shutdown
end
config t
int f0/0
standby 1 ip 172.16.0.254
standby 1 priority 200
standby 1 preempt
end
config t
ip routing
int f0/0
end
config t
hostname Switch2
vlan 1
ip address 172.16.0.4 255.255.0.0
no shutdown
end
ping 172.16.0.254
sh ip arp
do not have entry of HSRP virtual mac address
on router1:
int f0/0
ip add 172.16.0.2 255.255.0.0
standby 1 priority 101
standby  1 preempt
on 3550:
int f0/3
switchport mode access
switchport access vlan 1
int vlan 1
stanndby 1 preempt
on the 2950: just leave default config
Regards.
Alain
cadet alain
post a diagram here, your link is not working.
Regards.
Alain
port number is not the same as in the diagram, however, connection is correct to follow this diagram
Host A is simulated by Switch2
diagram is
on router1:
int f0/0
standby  1 preempt
on 3550:
int f0/3
int vlan 1
stanndby 1 preempt
Regards.
Alain
i use my older script this time success
the difference is just
ip routing
int f0/0
no switchport
should type ip routing first and then no switchport
above script is no switchport first and then ip routing
