Can't connect to switch module inside router
Chris Campbell
I am using the SM-ES2-24-P module in a 2951 router.  This is a layer 2 device, similar in capability to a Catalyst 2960.  I had previously gotten it working using some instructions from a previous discussion I found here on the forums.  But now, it isn't doing what I need, and I can't get into a console session using service-module.
I think there is something I don't fully understand about how this is supposed to connect with the router and pass traffic.  Can anyone help?
I can see it with CDP:
Device ID: Switch
Entry address(es):
  IP address: 10.2.2.2
Platform: cisco SM-ES2-24-P,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/1,  Port ID (outgoing port): GigabitEthernet0/25
Holdtime : 124 sec
Version :
Cisco IOS Software, C2960SM Software (C2960SM-LANBASEK9-M), Version 12.2(52)EX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 13-May-10 13:53 by prod_rel_team
advertisement version: 2
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF000000000000544A000D2B80FF0000
VTP Management Domain: ''
Native VLAN: 101
Duplex: full
Management address(es):
C2951-2#service-module embedded-Service-Engine 0/0 session
Trying 10.2.2.1, 2002 ...
% Connection refused by remote host
sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 10.2.2.1        YES unset  administratively down down
GigabitEthernet0/0         XXX.XXX.XXX.XX  YES NVRAM  up                    up
GigabitEthernet0/1         10.0.0.230      YES NVRAM  down                  down
GigabitEthernet0/2         10.0.6.1        YES NVRAM  up                    up
GigabitEthernet1/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet1/1         unassigned      YES unset  up                    up
Loopback0                  192.168.61.1    YES NVRAM  up                    up
Loopback1                  192.168.62.1    YES NVRAM  up                    up
NVI0                       192.168.61.1    YES unset  up                    up
Tunnel0                    192.168.91.1    YES NVRAM  up                    down
Tunnel1                    192.168.6.2     YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Template2          192.168.62.1    YES unset  down                  down
Vlan1                      unassigned      YES unset  up                    up
Vlan2                      10.2.2.1        YES NVRAM  up                    up
Vlan101                    10.0.101.1      YES manual up                    up
______
config:
interface Embedded-Service-Engine0/0
 ip unnumbered Vlan2
interface GigabitEthernet0/0
 ip address XXX.XXX.XXX.XX 255.255.255.128
 ip flow ingress
 ip flow egress
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed 100
 no cdp enable
 crypto map WIN_OUTSIDE_STRONG_MAP
interface GigabitEthernet0/2
 ip address 10.0.6.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet1/0
 no ip address
 shutdown
interface GigabitEthernet0/1
 ip address 10.0.0.230 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet1/1
 switchport access vlan 2
 switchport trunk native vlan 101
 switchport mode trunk
 no ip address
interface Virtual-Template2
 ip unnumbered Loopback1
 peer default ip address dhcp-pool dhcp-vlan99-pool
interface Vlan1
 no ip address
interface Vlan2
 ip address 10.2.2.1 255.255.255.0
interface Vlan101
 ip address 10.0.101.1 255.255.255.0
line 2
 access-class 20 in
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 access-class 20 in
 no exec
 stopbits 1
 flowcontrol software
line vty 0 4
 access-class 20 in
 exec-timeout 90 0
 transport input ssh
line vty 5 15
 access-class 20 in
 transport input ssh
2 Accepted Solutions
balaji.bandi
show admin down.
here is the reference guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html
BB
Reza Sharifi
This is the interface that connects the router to the switch internally. So, if you want to get to the switch use:
service-module GigabitEthernet1/1 session.
5 Replies 5
balaji.bandi
show admin down.
BB
Thanks.  I am now getting this:
Embedded-Service-Engine0/0 10.2.2.1        YES unset  up                    down
Protocol is down.  If it was a regular Ethernet port, I'd suspect unplugged cable, but that doesn't make sense here..
follow the guide have close look "Sample Output for Configuring the Cisco Enhanced EtherSwitch Service Module Interface on the Router"
BB
Reza Sharifi
Somehow I was on the wrong interface and a couple of other things.  Part of me being frustrated and not taking a break.  It's worth noting that depending on which slot the module is in, the gigabitethernet part will change.
