Can't login web interface but can login SSH and telnet
Can't login web interface but can login SSH and telnet of cisco 3560
after got problem i can login and monitor performance and see log after that logoff and try login again it show user password not correct
- i try change browser firefox, ie, chrome can access web but can't login.
- i try login ssh :OK!
- i try login telnet :OK!
- i try create new user can login ssh ,telnet but can't login web.
Please help me how to check this problem.
Thank you for all and i solving problems already
command : no ip http secure-server
and put command again: ip http secure-server
10 Replies 10
balaji.bandi
Using the GUI , you have must have permission of privilege level 15 access try below option :
create a user
Step 1
username admintemp privilege 15 privilege 15 secret admintemp
then runn the http services
Step 2
ip http server
ip http authentication login local
Step 3
management ip
http://X.X.XX
it will ask you username and pass
make sure you have right java version.
BB
I see my config and check with you recommend it correct
username cisco privilege 15 password 0 12343234
username Admin privilege 15 password 0 09876567
interface Vlan100
ip address 192.168.100.254 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip route 0.0.0.0 0.0.0.0 192.168.99.1
ip ssh version 2
ip scp server enable
The question in the original post was about failure in login for the web interface but success in login for telnet and ssh. The partial config posted shows that the web interface should authenticate using the locally configured user ID and password. So the users cisco and Admin should be able to login to the web interface. Are you telling us that these IDs do work or do not work for the web interface?
We have no information about authentication for telnet and ssh and so can not yet address differences in login success or failure. Can you post more of the config (most especially all of the aaa config and the config of the vty lines - complete config would be nice).
Rick
Rick
can you see my config
interface Vlan700
ip address 10.1.12.253 255.255.255.0
ip default-gateway 10.1.8.77
ip http server
ip access-list extended AutoQos-4.0-wlan-Acl-Bulk-Data
permit tcp any any eq 22
permit tcp any any eq 465
permit tcp any any eq 143
permit tcp any any eq 993
permit tcp any any eq 995
permit tcp any any eq 1914
permit tcp any any eq ftp
permit tcp any any eq ftp-data
permit tcp any any eq smtp
permit tcp any any eq pop3
ip access-list extended AutoQos-4.0-wlan-Acl-MultiEnhanced-Conf
permit udp any any range 16384 32767
permit tcp any any range 50000 59999
ip access-list extended AutoQos-4.0-wlan-Acl-Scavanger
permit tcp any any range 2300 2400
permit udp any any range 2300 2400
permit tcp any any range 6881 6999
permit tcp any any range 28800 29100
permit tcp any any eq 1214
permit udp any any eq 1214
permit tcp any any eq 3689
permit udp any any eq 3689
permit tcp any any eq 11999
ip access-list extended AutoQos-4.0-wlan-Acl-Signaling
permit tcp any any range 2000 2002
permit tcp any any range 5060 5061
permit udp any any range 5060 5061
ip access-list extended AutoQos-4.0-wlan-Acl-Transactional-Data
permit tcp any any eq 443
permit tcp any any eq 1521
permit udp any any eq 1521
permit tcp any any eq 1526
permit udp any any eq 1526
permit tcp any any eq 1575
permit udp any any eq 1575
permit tcp any any eq 1630
permit udp any any eq 1630
permit tcp any any eq 1527
permit tcp any any eq 6200
permit tcp any any eq 3389
permit tcp any any eq 5985
permit tcp any any eq 8080
ip sla enable reaction-alerts
access-list 100 permit ip any any
access-list 100 deny ip 192.168.1.0 0.0.0.255 10.1.0.0 0.0.255.255
access-list 100 deny ip 192.168.1.0 0.0.0.255 172.20.1.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
control-plane
service-policy input system-cpp-policy
no vstack
line con 0
password asdfghjkl;'
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
line vty 5 15
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
ap dot11 airtime-fairness policy-name Default 0
ap group default-group
ap hyperlocation ble-beacon 0
ap hyperlocation ble-beacon 1
ap hyperlocation ble-beacon 2
ap hyperlocation ble-beacon 3
ap hyperlocation ble-beacon 4
end
this sounds more like a browser problem than a problem with the 3560. Are you trying this from a Windows machine ? If so, try and disable the firewall...
Thanks for posting some additional configuration. It is helpful to see the configuration of the vty lines. Would you post the output of this command
show run | include aaa
Rick
Rick
I was facing this problem on all my devices with the GUI files installed and the HTTP(s) service enabled. Except for AP. The AP running config doesn't have the ip http authentication local line and the GUI works as intended. That's different.
Balaji, your hint was helpful. I wish, you are making much less typo for now
Thanks for the update telling us that you solved the problem by removing and re-adding the command. It is good to know this.
Rick
Rick
