Can't ping a directly attached switch.
jorgeborges
I recently configured an access layer switch port for a new printer VLAN. I was able to ping the switch from the printer and vice versa no problem. I then configured another access switch with the new VLAN but am unable to ping the second printer connected to it. The configurations are exactly the same except the second switch had switchport security configured. I unset the security settings but am still unable to ping. I CAN ping the original printer from BOTH access switches. Does anybody have any ideas?
13 Replies 13
InayathUlla Sharieff
Jorge,
Could you connect the printer to other spare port and apply the exact config as done on the 1st switch and let us know the result?
Inayath
Probably can't actually move the printer. I'm fairly certain it's not the printer itself because we put the IP address of the second printer on a laptop and plugged the laptop into the second switch and still couldn't ping.
Can you please share the respective configuration from both the switches and laptop ip address configured as well.
regards
Inayath
I would like to, but the network I manage them from is not connected to the internet for security purposes.
You must have a config as below :
SWA-PortA
switchport access vlan 28
SWB-PortB
switchport access vlan 29
SWCORE-PortC
switchport trunk allowed vlan 28,29
switchport mode trunk
This config is exactly as you have in your switch ?
Hello
Have you configured management ip address on the switches with a default gateway?
Are these two switch's connected together via a  trunk port?
Are you also allowing your vlans pertaining to the printers and pcs across that trunk?
Do you have vtp enabled.
sh int trunk
sh vtp status
sh vlan brief
res
Paul
Kind Regards
Paul
Yes the switches have a default gateway and management IP addresses. They aren't connected directly together but they do have trunk ports to the core switch-  yes, I added the vlan to the trunk. We are not using VTP.
If there are policy reasons not to post the configs would you be able to post the output of these commands from both switches
show vlan
show interface trunk
show ip interface brief
show ip arp
show ip route
Rick
Rick
Richard,
Unfortunately, I have no way to transfer the output of those results to a machine with internet connectivity. I can tell you that the VLAN in question, 28, is assigned to the correct interface and the interface shows as up/up. The show interface trunk lists vlan 28 as allowed and active and not pruned.
Both printer MAC addresses also show up in their respective MAC tables. The show ip arp for both show 2 identical IPs, plus their own.
Hello
Is this vlan 28 showing on  both switches in the vtp database
sh vlan brief
res
Paul
Kind Regards
Paul
Martin Carr
Level 4
Level 4
What are the addresses and S/M of both printers?
Martin
I finally figured it out. A rarely used switch that was moved from another location had a duplicate VLAN number that was being trunked. Thanks for everyone's input.
I am glad to know that you have resolved the problem. Thank you for posting back to the forum and letting us know that it is solved and what the problem turned out to be.
Rick
Rick
