Can't remote and ping Vlan IP Management
idrus-daud
I'm configuring new C1000 switch cascading with utp cable with 2960S. The new C1000 can work as well to the users connected to the port.
The problem, why i can't remotely go to the C1000 switch with IP 10.33.211.155. I only can ping the ip using console cable
Try changing your subnet mask for interface vlan 211 to either 255.255.255.0 or 255.255.255.128 for both since they are different.
They have different subnet masks.
-David
it seems like you missed transport input types in vty lines.
line vty 0 4
 password 7 113C30313A31021F0725
 login
 transport input none
line vty 5 15
 password 7 00313A32297802150C2E
 login
 you need to enable required protocols there such as ssh.
use below commands. then try to ssh to management IP. also mentioned by @David Ruess above, make sure network subnets are properly configured.
line vty 0 4
 login
 transport input ssh
line vty 5 15
 login
 transport input ssh
Good luck
KB
Jitendra Kumar
you have to set transport input showing None
line con 0
password 7 02332D6F262506324F41
logging synchronous
login
line vty 0 4
login
line vty 5 15
login
you have to set as SSH.
Jitendra
Jitendra
