Can the following C3750 switches be mixed stacked (Stackwise)?
FirasChahine
Hello everyone,
I currently have these two C3750 switches stacked:
Switch Ports Model              SW Version            SW Image
     1 52    WS-C3750G-48TS     15.0(2)SE11           C3750-IPSERVICESK9-M
*    2 52    WS-C3750G-48TS     15.0(2)SE11           C3750-IPSERVICESK9-M
Is it possible to add the switch below to the group?
*    3 54    WS-C3750X-48P             15.2(4)E10            C3750E-UNIVERSALK9-M
C3750X#show license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: lanbase
        Period left: 0  minute  0  second
If so, is there something I need to do aside from simply connecting up the stackwise ports?
Thank you in advance!
Firas
16 Replies 16
@Leo Laohoo  @balaji.bandi  you were right, it did not work after all. I had to downgrade in order for the 3750X to function. Although it was initially part of the stack, none of its ports came up. Lesson learned
     3 54    WS-C3750X-48P      15.0(2)SE11           C3750E-UNIVERSALK9-M
Switch/Stack Mac Address : 0008.30a4.3580
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
 1       Member 0019.5691.8e00     1      0       Ready
*2       Master 0008.30a4.3580     1      0       Ready
 3       Member f40f.1bc4.3e00     1      3       Ready
That's the basic rule of the stack all should be the same version, if not how will the command syntax matches?
Glad all work as expecting.
BB
