Can you define speed of cable ?
What Is The Difference Between Cat 5, Cat 5e, and Cat 6 Cable? Please define with speed and length.
Charles Hill
"Cat6 cables, also called Category 6 or Cat 6cables, provide lower crosstalk, a higher signal-to-noise ratio, and are suitable for 10GBASE-T (10-Gigabit Ethernet), while Cat5e cables support only up to 1000BASE-T (Gigabit Ethernet)."
http://www.diffen.com/difference/Cat5e_vs_Cat6
Category
Type
Spectral B/W
Length
LAN Applications
Notes
Cat3
UTP
16 MHz
100m
10Base-T, 4Mbps
Now mainly for telephone cables
Cat4
UTP
20 MHz
100m
16Mbps
Rarely seen
Cat5
UTP
100MHz
100m
100Base-Tx,ATM,CDDI
Common for current LANs
Cat5e
UTP
100MHz
100m
1000Base-T
Cat6
UTP
250MHz
100m
Emerging
Cat7
ScTP
600MHz
100m
http://discountcablesusa.com/ethernet-cables100.html
Hope this helps
Please rate helpful posts
