high cpu due to ipv6 multicast traffic from clients in cisco 4506-E switch
vijay kumar
Level 2
Level 2
Hi Folks ,
We are facing high cpu (always 99%) in our cisco 4506-E switches. Then found that huge ipv6 multicast packets are hitting to switch CPU.
Index 1:
36 days 18:9:45:440850 - RxVlan: 102, RxPort: Te1/1
Priority: Normal, Tag: Dot1Q Tag, Event: 21, Flags: 0x40, Size: 90
Eth: Src A0:48:1C:86:78:7A
Index 2:
36 days 18:9:45:442373 - RxVlan: 102, RxPort: Te1/1
Eth: Src F0:92:1C:F2:91:CE Dst 33:33:FF:27:F3:C2 Type/Len 0x86DD
Index 3:
Is there a way that we can configure in switch to not process theese packets. Or only way to disable IPV6 functionality in clients?
Vijay.
5 Replies 5
LJ Gabrillo
Level 5
Level 5
Hi Vijay,
I doubt that the cause of that high CPU is the multicast addresses. There might be a loop in your network.
Kindly do isolation of each of your backbones.
one-by-one, remove your backbones from the different switches, while constantly doing "show processes cpu"
Once you hit a backbone that suddenly decreases the CPU, your loop is in that segment. Try to find it.
Hi Isgabrillo ,
Thanks for your suggestion .We didn't see any STP TCN in our switches . The  debug previously I have posted has packets from uplink. But we able to see lot of traffic from access ports (Connected with end machines) also.All the packets destined to IPV6 multicast address 33:33:FF:27:F3:C2.
ndex 1:
36 days 17:47:37:910324 - RxVlan: 102, RxPort: Gi4/27
Priority: Normal, Tag: No Tag, Event: 21, Flags: 0x40, Size: 90
Eth: Src A0:48:1C:86:38:97 Dst 33:33:FF:27:F3:C2 Type/Len 0x86DD
Index 4:
36 days 17:47:37:921663 - RxVlan: 102, RxPort: Gi4/29
Eth: Src A0:48:1C:86:7A:BE Dst 33:33:FF:27:F3:C2 Type/Len 0x86DD
I would recommend tracking down whoever owns that mac address: 33:33:FF:27:F3:C2
a show arp should do the trick
Now, try removing that host/server for a short time, see if the CPU improves (like to normal levels)
worse case that MAC may be a security/virus beach considering it continually asks other hosts for data.
i would suggest create an acl to drop this mac address to prevent the high cpu quickly.
use vacl right away.
Hello. I have same issue with 4500. I found port that send traffic, shutdown it and cpu load normalized.
User said that some time before he send pc to sleep.
Is you found any reason of traffic?
