Cat 2960 routing
qsosan20
I have cat 2960 with default router to x.x.x.10 , however one destination (y.y.y.y) is using another gateway which is x.x.x.3 , how i can force this to use the default route .10 ?
sh ip route
Default gateway is x.x.x.10
Host                 Gateway         Last Use          Total Uses            Interface
y.y.y.y                x.x.x.3           0:00                 1100                   Vlan61
Try
Clear arp
Add GW again to overriding the old wrong one
MHM
6 Replies 6
balaji.bandi
change from default-gateway to ip route command.
example :
no Default gateway x.x.x.10
ip route 0.0.0.0 0.0.0.0 x.x.x.10
if you like one of the host to route to x.x.x.3
ip route y.y.y.y 255.255.255.255 x.x.x.3
BB
Host GW is different than SW GW'
Host GW is control by dhcp or by manually add GW in host.
MHM
qsosan20
Issue solved after rebooting the switch , seems the route entry was stuck !!
However i have another switch which having the same issue , and i don't want to reboot , is there any command to clear stuck routes ?
Try
Clear arp
MHM
That works ,
Thank you ,
i  have misunderstood the requirement of OP  -aha ! reboot resolves many issue - glad to know.
BB
