CAT 3750 Command to set boot system switch 2 failed
TommyP163
I'm attempting to update the firmware on some 3750 stacked switches and I'm having trouble setting the boot variable on the secondary switches. I keep getting the following error:
%Command to set boot system switch 2 flash:c3560-ipservicesk9-mz.122-55.SE12.bin on switch=2 failed
I've transferred the .bin file to both of the switch's flash memory but only switch 1 is accepting the change.
#do sh flash
Directory of flash:/
2 -rwx 7816 Mar 1 1993 00:02:38 +00:00 vlan.dat
3 -rwx 9888 Apr 12 2019 15:19:24 +00:00 config.text
4 -rwx 64050 Mar 1 1993 00:06:06 +00:00 config.text.backup
5 -rwx 5 Apr 12 2019 15:19:24 +00:00 private-config.text
6 drwx 192 Mar 1 1993 00:14:19 +00:00 c3750-ipservices-mz.122-50.SE5
428 -rwx 36 May 25 1993 22:49:39 +00:00 eem_pnt_2
429 -rwx 13013140 Apr 4 1993 23:01:25 +00:00 c3750-ipservicesk9-mz.122-55.SE12.bin
430 -rwx 5 Mar 1 1993 00:06:06 +00:00 private-config.text.backup
431 -rwx 1048 Apr 12 2019 15:19:24 +00:00 multiple-fs
32514048 bytes total (5114368 bytes free)
Metro-3750-SW02(config)#do sh flash2
Directory of flash2:/
2 -rwx 7816 Mar 1 1993 00:02:59 +00:00 vlan.dat
3 -rwx 5 Apr 12 2019 15:19:24 +00:00 private-config.text
4 -rwx 9888 Apr 12 2019 15:19:24 +00:00 config.text
5 -rwx 13013140 Apr 4 1993 23:07:29 +00:00 c3750-ipservicesk9-mz.122-55.SE12.bin
6 drwx 192 Mar 1 1993 00:13:37 +00:00 c3750-ipservices-mz.122-50.SE5
428 -rwx 9446 Mar 6 2018 13:00:19 +00:00 config.text.backup
429 -rwx 5 Mar 6 2018 13:00:19 +00:00 private-config.text.backup
430 -rwx 1048 Mar 1 1993 00:51:34 +00:00 multiple-fs
32514048 bytes total (5169664 bytes free)
#boot system switch all flash:c3560-ipservicesk9-mz.122-55.SE12.bin
%Command to set boot system switch all flash:c3560-ipservicesk9-mz.122-55.SE12.bin on switch=2 failed
balaji.bandi
you Device  and you mentioned was 3750 and you have image loaded in the device 3750XXXX.bin
but you try to add 3560 boot valiable - correct it.
change to below :
BB
balaji.bandi
change to below :
BB
You're right I had copied the command I was using for a different switch. Thanks!
#sh boot
BOOT path-list : flash:c3750-ipservicesk9-mz.122-55.SE12.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Switch 2
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : no
Auto upgrade path :
