In IOS, you can configure each individual ports on a module to run either Pagp or LACP or mix and match. How does it work with Cat-OS running 8.x. I did some search on CCO, and according to a document the entire module needs to be converted from default PAGP to LACP by "Set channelprotocol LACP 1 to set module 1 for LACP. Does Cat-OS run PAGP by default?
I already have switch running Cat-OS connected to another switch with port-channels (pagp by default), but need to convert some of the ports on the module to support LACP so I can connect to my HP Virtual Connect/C7000 blade enclosure. Is it possible to convert to LACP on port basis only?
