01-12-2022 07:57 AM
I would like to configure LDAP authentication to manage the switch. With the Web Gui I can't configure it. With the CLI I tried, I can connect to the server, but I can't authenticate. Do you have any solution?
Solved! Go to Solution.
01-12-2022 10:23 AM
never tried it myslelf, we use TACACS/ Radius (that intern use LDAP for authentication, both GUI and CLI)
direct integrate with LDAP will not have ability login CLI using LDAP
some reference guide
if you aleady configured enable debug and check the logs both the side.
=====️ Preenayamo Vasudevam ️=====
01-12-2022 10:23 AM
