Catalyst 2960 Switch in Switch: mode
asheemy
I have Cat 2960G switch i upgraded from xmodem but when i reboot it goes to switch: mode again and everytime i have to issue boot flash:c2960-lanbasek9-mz.122-55.SE11.bin command.
2 Accepted Solutions
Julio E. Moisa
It looks like a problem with the image or it could be a corrupted/damaged image. Have you verified if the IOS is on the flash:
dir flash:
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Actually the switches dont support nat.
8 Replies 8
Julio E. Moisa
dir flash:
Yes when i issue dir flash i can see the image file name and when i issue from switch: mode boot the image it is booted from the the IOS and i can access the switch and do all configuration but when the switch turned off it goes to switch: mode.
i have used the suggested ios file name from cisco.
There are 2 ways to correct it, one if you are over rommon and the the other option if you are over the proper image running.
If you are in rommon (switch:) mode, execute this command:
confreg 0x2102
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html#anc13
If you are running the proper image and you can execute your configurations, you need to change the register to 2102
conf t
config-register 0x2102
write memory
*Once you have execute the command you can reboot the switch and verify the proper functionability.
http://netiisproperties.com/help/cisco_-_changing_the_configuration_register.htm
Hope it is useful
In Catalyst WS-C2960G-24TC-L  configuration register command invalid even confreg
^ % Invalid input detected at '^' marker.
SW1111(config)#
Did you try over Switch mode (stop at step 6) Clic?
confreg 0x2102
then
press reset
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/5...
 Actualy the IOS Image has an issue.
DJX995
Level 3
Level 3
Without a console log, we are shooting in the dark.
If you can issue" boot flash:path-to-image.bin", this probably means the image is fine but the boot var isn't set correctly.
I think the syntax is set BOOT flash:path-to-image.bin in ROMON
