Catalyst 2960: Unexpected exception to CPUvector 1100
maucapina
Hi Friends
I have a problem with my cisco catalyst switch 2960, an unexpected event occur, which causes the switch was completely inhibited and, the message is presented on the console is as follows:
Unexpected exception to CPUvector 1100, PC = 34D6CC
-Traceback= 34D6CC 349AC8 970F5C 715500 9AAE0C 9A5050
=== Flushing messages (00:27:28 UTC Mon Mar 1 1993) ===
Buffered messages:
00:00:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
00:00:45: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:47: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:47 UTC Mon Mar 1 1993 to 00:00:47 UTC Mon Mar 1 1993, configured from console by console.
00:00:47: %SYS-5-CONFIG_I: Configured from memory by console
00:00:47: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)FX, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 12-Oct-05 22:05 by yenanh
00:00:49: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
00:00:49: %LINK-3-UPDOWN: Interface FastEthernet0/3, changed state to up
-Output ommited-
Queued messages:
Data TLB Miss Exception (0x1100)!
SRR0 = 0x0034D6CC SRR1 = 0x00029210 SRR2 = 0x00416974 SRR3 = 0x00021200
ESR = 0x00000000 DEAR = 0x04E49228 TSR = 0x8C000000 DBSR = 0x00000000
CPU Register Context:
Vector = 0x00001100 PC = 0x0034D6CC MSR = 0x00029210 CR = 0x48000084
LR = 0x00349AC8 CTR = 0x00349A94 XER = 0x4000001F
R0 = 0x03E80000 R1 = 0x0137E1B0 R2 = 0x00000000 R3 = 0x00FA0000
R4 = 0x0137E1C0 R5 = 0x00ED52F4 R6 = 0x00ED53C8 R7 = 0x00000000
R8 = 0x00029210 R9 = 0x00FC9228 R10 = 0x00FA0000 R11 = 0x00E10000
R12 = 0x00192831 R13 = 0x00110000 R14 = 0x007154DC R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x007154BC R29 = 0x00000000 R30 = 0x00FA0000 R31 = 0x00000000
Stack trace:
PC = 0x0034D6CC, SP = 0x0137E1B0
Frame 00: SP = 0x0137E1B8 PC = 0x006EA9C4
Frame 01: SP = 0x0137E1C8 PC = 0x00349AC8
Frame 02: SP = 0x0137E1E0 PC = 0x00970F5C
Frame 03: SP = 0x0137E1F0 PC = 0x00715500
Frame 04: SP = 0x0137E1F8 PC = 0x009AAE0C
Frame 05: SP = 0x00000000 PC = 0x009A5050
SwOOPP-2 uptime is 27 minutes, 34 seconds
cisco WS-C2960-24TT-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
Processor board ID FOC1017X2JE
-Output ommited-
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c2960-lanbase-mz.122-25.FX/c2960-lanbase-mz.122-25.FX.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
- Output ommited-
Initializing flashfs...
flashfs[1]: 6007 files, 7 directories
-Output ommited-
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
Thanks in advance for your help!!!
Marcelo
Marcelo,
I am very happy to hear that! It has been a pleasure.
Best regards,
Peter
5 Replies 5
Peter Paluch
Hello Marcelo,
I suggest first trying to upgrade the IOS. The 12.2(25)FX was, as far as I know, the initial IOS version for the 2960 series and it is now superseded by the 12.2SE track. The 12.2(25)FX is not even available for download so Cisco has obviously had its reasons for withdrawing it.
The current version of the IOS for the 2960 series is the 12.2(50)SE3.
If upgrading the IOS does not remove the problem then I am afraid you will have to contact the TAC support, as these types of exceptions are generally hard to diagnose and correct without proper guidance.
Best regards,
Peter
Thanks for your help Peter!!!
The problem was resolved
Marcelo
Marcelo,
Best regards,
Peter
Can you please suggest what remedy steps you took to solve this issue, as even I am facing it on one of our 500 Catalyst switches.
Hi Sundeep
The IOS upgrade solved this issue with catalyst 2960. If this action does not resolve the problem, you should contact the TAC.
Marcelo
