HSRP on same subnet server's are directly connectd
skylarkblr
Hi All,
      I need some clarification on Configuraing HSRP on 4968 switches . we have 2 4968 namely sw1 and sw2 and vlan's 10 and 20 now we try to connect two servers name server 1 and server 2.
Server 1 as connected on Sw1
Server 2 as connected on Sw2
and both the servers are in same vlans (single subent) vlan 10, and the gateway of the server will be the vlan's VIP ip (HSRP), on this case can both the servers are on live or only the server 1 on sw1 will live.
Kindly clarify
G.MOHAN
6 Replies 6
Edison Ortiz
Both servers should be up and running as long as they have unique IP addresses from Vlan 10.
Hi Edtison,
     Thanks for your update need some more clarity on the same request
Switch 1
interface Vlan10
description ####Server VLAN####
ip address 192.168.64.201 255.255.255.0
standby ip 192.168.64.200
standby priority 120
Switch 2
interface Vlan10
ip address 192.168.64.202 255.255.255.0
standby priority 110
My server ip are 192.168.64.1  to 10 are connected on Switch 1 and 192.168.64.20 to 30 are connectd on Switch 2
my question  i can able to access all servers from my user vlan20 ie 192.168.64.1 to 30
G.MOHAN
I don't see why not.
Satya Narra
Hello Mohan,
Your ip address for user vlan overlaps with server vlan. Both 192.168.64.0/24 networks.
Hi ,
my user vlan are in different subnet not in server vlan subnet
Oops, I thought your server ip address are 192.168.64.1 to 30.
Yep, it should not be a problem.
