Catalyst 2960C > PoE > 7960 phone
Hi!
someone gave me 5 cisco 7960 ip phones with which i'm currently having fun. Sadly i only have one power cube to power them, so i've been looking into PoE. Could someone tell me if the
Catalyst 2960C-12PC-L
switch is retro-compatible with pre-standard PoE, and if i will be able to power my 7960 ip phones with it?
thank you ever so much.
xxxx
sam
Mark Malone
Phone supports 802.3af , switch supports it too so should be ok to get poe
i see that supported
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-c-series-switches/data_sheet_c78-639705.html
● IEEE 802.1D Spanning Tree Protocol
● IEEE 802.1p CoS Prioritization
● IEEE 802.1Q VLAN
● IEEE 802.1s
● IEEE 802.1w
● IEEE 802.1x
● IEEE 802.1AB (LLDP)
● IEEE 802.3ad
● IEEE 802.3af
● IEEE 802.3ah (100BASE-X single/multimode fiber only)
● IEEE 802.3x full duplex on 10BASE-T, 100BASE-TX, and 1000BASE-T ports
● IEEE 802.3 10BASE-T specification
● IEEE 802.3u 100BASE-TX specification
● IEEE 802.3ab 1000BASE-T specification
● IEEE 802.3z 1000BASE-X specification
Flexible Power Options
The Cisco Unified IP Phone 7960G supports Cisco Prestandard Power over Ethernet (PoE), allowing powering from any of the Cisco Inline Power-capable blades and boxes. In addition, it supports IEEE 803.af PoE. The phone can be powered locally with a power supply (part number CP-PWR-CUBE-3).
Leo Laohoo
Switch supports PoE.
Look at the output to the command "sh power inline".
