Catalyst 2960X vs 9200 series
Greetings,
I have to replace/change the WS-C2960S-24TS-L.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/eos-eol-notice-c51-733348.html
It is telling to use WS-C2960X-24TS-L.
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/index.html
It is telling me to switch to something new: Catalyst 9200 Series switches.
Have you used the 9200 and would say it is better even though it is new whereas the 2960X are long time in the marked and stable.
Please advise,
Edouard.
balaji.bandi
Cat 2960 will be fade from the market soon, as EoL announced was June 2019, I do not believe cisco official shipping any devices until some partner has stock in place.
as per the Software support and security patches ended in March 2020. (some support end until 2024)
Cisco new catalyst replace same features with the same costing I guess depends on where you buying.,
if I were you, I move to Cat 9200 as it has long term support and good Return of investment, rather going to the kit which was EoL.
By saying that you need to also look a support model, it changing in new Cat 9200, Essential / Advantage, 3 years, and 5 years kind of support.
BB
balaji.bandi
BB
Leo Laohoo
There is not enough information to say whether 9200/9300 or even the Catalyst 1000 is the appropriate upgrade path to replace the 2960X.
